Right now I have to mouse over the ‘Done’ button and hit it to dismiss the preview window.
Hitting either the escape or Enter key should also dismiss it.
Don’t the standard user interface keyboard shortcuts work?
Which OS are you running CM on?
I think you mean CTRL-F4 (close a window or tab in a running app) ?
ALT-F4 is supposed to shut the application down.
None of those shortcuts closed the preview. The 4th closed the app.
This is Windows 10 (Surface Pro), using the latest CM.
