Hi - I’m wondering if anyone has recommendations for a large bed laser engraver.
I’ve considered adding a laser module to my XXL pro - but from a work flow perspective it makes sense to keep these separate, space isn’t an issue for ,e either
I need something with a working area of at least 24”x24”. I can’t seem to find anything that size easily - and would like to start with some recommendations first.
Thanks for any advice - sorry if this isn’t quite carbide related -
Thanks - they do have an extender that will extend X axis out to I think 800 mm - but they don’t change Y axis which is still too small at 400 mm (iirc)
To get the sizes I need it looks like I need to step into industrial level lasers - but still researching
I saw a YouTube video where a teenage girl took the Ortur Laser Master 2 (which was current at the time) that had a 400mmx400mm work area and she just bought longer extrusions and swapped them out to create a larger work area (there was a bit more to it than that, but not much.
Can’t find the clip now, but it totally looked doable. The trick is to get a laser that uses standard extrusions.
