I need to do a large 40" long x 17" tall cut on a 2.5" thick slab of wood for a wedding present. I have figured out where to separate for the tile but have never done vertical work and don’t know how to change the settings for that.
I plan to fill the cut with epoxy and am looking for recommendations for bit settings (end mill or v-carve and depth) to do the best as I only have on chance at this.
Since the slab is 2.5" thick I had to come up with a new way to secure it. This is after I found out that the regular clamps would NOT hold it. I ended up having to resurface the cut into a recess and redo the cut with the new clamps.
I then filled the lettering with epoxy. It worked pretty good but my question for you experienced at this is - did you pretreat the surface to prevent the epoxy from migrating into the wood around the lettering?
