Largest Bottom Cleaning Bit that can be used on XXL Shapeoko
Hello Everyone!
I use a Shapeoko XXL. I am wondering the largest cutting diameter “bottom cleaning” router bit that can be used? I have some plunge cuts that are large is surface area and using a 1/4" diameter takes forever.
Thanks
Josh
I presently am using a 1.312" (33mm) diameter cutter.
This link may help.
This is the end mill I use. It does well and leaves a great finish.
[Amana Tool 45525](Amana Tool 45525 Carbide Tipped 1-1/8 Dia x 1/2 CH x 1/4 Shk x 1-19/32 Long Spoilboard Surfacing & Flattening 3-Flute Router Bit 5.0 out of 5 stars 4 https://www.amazon.com/dp/B07PYX5S5J/ref=cm_sw_r_cp_tai_ah3eFbCC1W696)
