Redo from a design i did on my ShapeOKO Pro CNC Machine.
Done with Lightburn
- Cut everything out as is
- Cut out a full size blank backing plate
- Paint the backing plate white under where the stars will go
- Paint the top plate white
- Paint the stripes red
- Paint the stars plate dark blue metalic
- Glue the top plate and backing plate together
- Glue the stars box back into the backing plate
- Glue the stripes back into the backing plate.
- DONE
SVG File - Right click to Save
Lightburn File
American Flag .zip (81.5 KB)
You could also do this the opposite way. Just paint the backer board all white. Then use the cutout top layer as a template to glue the parts on. So the star box and all the red flag lines would be raised. Or change the cut/layers to engrave instead of cut when you make the backer board and use that as a template to glue the parts back on. Ill try that on the next one
