Honeycomb grids can be found on ebay I have seem them before on there
@Julien you could always use two smaller honeycomb grids and put them side by side in the downdraft box.
True. I may need to take another look, a quick search only came up with integrated/ready-to-roll honeycomb beds that were not only too small but also very expensive. I could not find where to procure the honeycomb metal grid alone, but I did not spend a lot of time searching either
I wonder how much of the burn marks on the backside is from the paint getting burned off the grid?
Not sure about in France, but they’re are ebay sellers that the honeycomb. Or you could just elevate your knife table and build a box around it.
After a 3 year hiatus, inspired by this thread, back to lasering.
Snapped up @DiscoJon 7 watt JTech unit plus mount and other stuff, thanks Jon!
Prototype HDM smoke eater done, seems to work well.
Anyone care to show examples of their air-assist setups?
Looks awesome bud! Good work.
Jtech has an air assist nozzle now.
I have a 6mm line hooked from my air compressor, to a regulator/ dryer, then through the cable chain with push to connect fittings.
