Left stepper only holds position
After connecting when i initialize left stepper holds as right stepper moves toward home.
The right stepper starts skipping. Ive verified everything good to the controller and worked with support they sent me a new controller as well as wiring harness which is so much nicer than the original. That was a pleasant surprise. I replaced the harness and controller and tried to initialize and had the same issue. I tried setting up like new hoping it was a firmware issue and had the same results. If I understand correctly there are not separate settings for the left and right driver, so it should be receiving the same pulses as the left.
Ive also tried it on another laptop that’s never had carbide motion on it.
Ill continue working with support, but curious want everyone thinks
