By chance, does anyone have any legacy carbide motion install (.deb) files for carbide motion version 5 for the raspberry pi?
I run build 579 but my RPi SD has become corrupt and I have undetaken a fresh install with CM6 but they have removed the “manual travel dimensions” from settings!? I run a VFD with SuckIt dust boot and SuckItEars so my X travel is not per standard XXL - the spindle crashes into the gantry with standard settings. I cannot understand why this setting has been removed.
I have reached out to support but they have indicated that historic/legacy build releases are not kept/archived!? which frankly is mind boggling.
You can still change the travel parameters manually in CM6.x for RPi.
Once you’ve connected to your CNC,
Click on the Build # in the bottom left tab, click Open Data Directory, open the Shapeoko.Json file in text editor to see CM parameters & change to your hearts’ content.
Once saved, close CM & restart to check that your new parameters are in play. Do a reboot to be absolutely sure.
Be sure to check your machine’s operation thoroughly after any manual edits. Any changes you make there are on you.
