Hey everybody. I’m have trouble figuring out how to do cutouts. I have a capital letter “M” that needs cutout of 1/4 inch stock. The left side is approx 9” and the right side is approx 8” (Complete guesstimations) but the effect is to be slightly diagonal.
Any ideas how I would set this up in carbide create or is it possible?
Then select the proper tool and also outside for offset direction.
You can also add tabs under the edit tabs section. Tabs are little segments of stock left to keep the piece to the stock.
Oh, either find a font that does what you want (sort of) or use inkscape to create a .svg file that you can import in that has a letter M.
Or the very tedious option you could use the polyline tool (the one that looks like a rotated Z in the design tool section), to draw out your desired letter. You could use boxes to help you keep within constraints.
I was considering the polyline. But I don’t know how to get it to the exact measurements on carbide. Or how to make it the exact measurements period on carbide create. Inkscape is a whole new learning experience for a beginner like me.
