Level Table Slats - McFly
Hi All,
I am leveling my table slats and noticed this scalloped pattern where left to right looks ok, but front to back shows that the front is slightly lower than the back. Is there a way to adjust the Z?
Thanks,
Mark
I should have also noted tht the head shows 0.1 degree higher in the back. The table shows a 0.3 degree tilt due to the floor level. So that leaves 0.2 diffrence. Is this OK?
Thanks,
Mark
See pg. 18 and following of:
Thanks William!
Mark
I used Reynolds heavy duty aluminum foil, which measured exactly 0.001" thick. It required six layers to get it perfect. Scalloped effect is now gone!
