In the Library, all the items should be clean vectors. The ‘Interlocking_Hearts_2’ has several unclosed vectors.
Here is a version suitable for V Carve.
Interlocked Hearts.zip (9.1 KB)
Huh, I attached a clean SVG, but the forum doesn’t show it. PM me if you want it.
EDIT - Attached zip instead, that worked.
Try zipping it first, then attach the zip file
I wonder if the reason is there would be several ways to use this. If you wanted them layered, you would need a complete top heart (left), and a union (like your fix) for the 2nd layer. ??
