Lightburn Configuration
I recently bought a JTEC laser for my 5 Pro and I am trying to configure Lightburn so I can use my CNC and laser in the same project. I have figured out the offset between the spindle head and the laser. That is not an issue.
The issue is the X and Y axis are backwards in lightburn. I have macros set up for Lightburn for the laser and revert it back to the CNC.
To switch to lightburn I have this including the offset for the 5Pro:
$10=0
$30=1000
$32=1
G10 L2 P1 X-1250 Y-1250
To switch back I have:
$10=255
$30=24000
$32=0
G10 L2 P1 X0 Y0
I have tried it with and without the G10 offset. I have also tried to play with the $3 and $23 settings to no avail.
I’m at a complete loss and could use some guidance for those of you using lightburn.
Thanks, Christopher
I guess with anything if you mess with it enough you will figure it out. This setting in light burn made it all work correctly.
