SO3 user here. Could someone provide a link to where I might purchase the connectors for wiring limit switches to the Carbide Motion board? I’m not sure what those white female connectors are called.
Those are Molex KK-series .100" pitch 2-pin headers. The mating shell is (for example)
http://www.digikey.com/product-search/en?mpart=0022012027&vendor=900
and the associated contact would be (for example)
http://www.digikey.com/product-detail/en/0008500114/WM1114-ND/26475
If you’re in the US and have a Fry’s Electronics near, they sell the shells and contacts.
Awesome! Thanks a ton, Randy.
The spacing is a little tight for individual headers, so we use a 12-pin connector, this one to be exact: http://www.digikey.com/product-detail/en/22-01-2127/WM2021-ND/172001
If you only care about the limit switches then this 6-pin connector should do: http://www.digikey.com/product-detail/en/0022012067/WM2015-ND/171995
Alright. I’ll order some of those too. Thanks for the tip.
