Error message longer than posting allows- sometimes it says thread 4 other times thread 5 now thread seven as the crashed thread. Machine is lubricated and as clean as I can get it without disassembly. What to do next?
Translated Report (Full Report Below)
Process: Carbide Motion [71758]
Path: /Applications/Carbide Motion.app/Contents/MacOS/Carbide Motion
Identifier: com.yourcompany.Carbide-Motion
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-10-30 10:43:32.8246 -0500
OS Version: macOS 12.6.6 (21G646)
Report Version: 12
Bridge OS Version: 7.5 (20P5058)
Anonymous UUID: D024178D-EE51-6659-7269-E84BD268B20C
Sleep/Wake UUID: 8DF43B07-260D-49C8-8FC8-64EC9E3CBF42
Time Awake Since Boot: 850000 seconds
Time Since Wake: 420 seconds
System Integrity Protection: enabled
Crashed Thread: 7 Machine Thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [71758]
VM Region Info: 0 is not in any region. Bytes before following region: 4533723136
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 10e3b2000-10ec16000 [ 8592K] r-x/r-x SM=COW …arbide Motion
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x7ff8050f996a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff8050f9cd8 mach_msg + 56
2 CoreFoundation 0x7ff8051fd34d __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff8051fb9d8 __CFRunLoopRun + 1276
4 CoreFoundation 0x7ff8051fae1c CFRunLoopRunSpecific + 562
5 HIToolbox 0x7ff80deab5e6 RunCurrentEventLoopInMode + 292
6 HIToolbox 0x7ff80deab34a ReceiveNextEventCommon + 594
7 HIToolbox 0x7ff80deab0e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
8 AppKit 0x7ff807c35f6d _DPSNextEvent + 927
9 AppKit 0x7ff807c3462a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
10 libqcocoa.dylib 0x110bb9f6e 0x110b84000 + 221038
11 QtCore 0x1111acf8f QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 431
12 QtWidgets 0x10f75b7ce QDialog::exec() + 526
13 Carbide Motion 0x10e67994c MainWindow::onError(QString) + 124
14 Carbide Motion 0x10e6820dd 0x10e3b2000 + 2949341
15 QtCore 0x1111db3c1 QObject::event(QEvent*) + 753
16 QtWidgets 0x10f59b2aa QWidget::event(QEvent*) + 4826
17 QtWidgets 0x10f6aba85 QMainWindow::event(QEvent*) + 277
18 QtWidgets 0x10f55e65d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269
19 QtWidgets 0x10f55fa01 QApplication::notify(QObject*, QEvent*) + 497
20 QtCore 0x1111b19a4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
21 QtCore 0x1111b2bde QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 878
22 libqcocoa.dylib 0x110bbab19 0x110b84000 + 224025
23 libqcocoa.dylib 0x110bbb288 0x110b84000 + 225928
24 CoreFoundation 0x7ff8051fd15b CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 17
25 CoreFoundation 0x7ff8051fd0c3 __CFRunLoopDoSource0 + 180
26 CoreFoundation 0x7ff8051fce3d __CFRunLoopDoSources0 + 242
27 CoreFoundation 0x7ff8051fb858 __CFRunLoopRun + 892
28 CoreFoundation 0x7ff8051fae1c CFRunLoopRunSpecific + 562
29 HIToolbox 0x7ff80deab5e6 RunCurrentEventLoopInMode + 292
30 HIToolbox 0x7ff80deab34a ReceiveNextEventCommon + 594
31 HIToolbox 0x7ff80deab0e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
32 AppKit 0x7ff807c35f6d _DPSNextEvent + 927
33 AppKit 0x7ff807c3462a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
34 AppKit 0x7ff807c26cd9 -[NSApplication run] + 586
35 libqcocoa.dylib 0x110bba003 0x110b84000 + 221187
36 QtCore 0x1111acf8f QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 431
37 QtCore 0x1111b1fb2 QCoreApplication::exec() + 130
38 Carbide Motion 0x10e6676e5 main + 5157
39 Carbide Motion 0x10e3bc544 start + 52
Thread 1:
0 libsystem_pthread.dylib 0x7ff805131f48 start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
0 libsystem_kernel.dylib 0x7ff8050fc3da __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff805136a6f _pthread_cond_wait + 1249
2 libc++.1.dylib 0x7ff805094db3 std::__1::condition_variable::__do_timed_wait(std::__1::unique_lockstd::__1::mutex&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >) + 93
3 Carbide Motion 0x10e66a00e 0x10e3b2000 + 2850830
4 Carbide Motion 0x10e669f1d 0x10e3b2000 + 2850589
5 libsystem_pthread.dylib 0x7ff8051364e1 _pthread_start + 125
6 libsystem_pthread.dylib 0x7ff805131f6b thread_start + 15
Thread 7 Crashed:: Machine Thread
0 Carbide Motion 0x10e6b23c5 MachineController::onGrblCycleChanged(Grbl::cycle_type) + 277
1 QtCore 0x1111e2d0c QMetaObject::activate(QObject*, int, int, void**) + 3132
2 Carbide Motion 0x10e703ade Grbl::cycleChanged(Grbl::cycle_type) + 62
3 Carbide Motion 0x10e6a78ec Grbl::processLine(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >) + 7484
4 Carbide Motion 0x10e6a5afa Grbl::processBuffer() + 314
5 Carbide Motion 0x10e6a3ef1 Grbl::serialDataReady() + 177
6 QtCore 0x1111e297b QMetaObject::activate(QObject*, int, int, void**) + 2219
7 QtSerialPort 0x10ef0018f 0x10eef8000 + 33167
8 QtSerialPort 0x10ef02726 0x10eef8000 + 42790
9 QtWidgets 0x10f55e65d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 269
10 QtWidgets 0x10f55fa01 QApplication::notify(QObject*, QEvent*) + 497
11 QtCore 0x1111b19a4 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
12 QtCore 0x111208da3 QEventDispatcherUNIXPrivate::activateSocketNotifiers() + 99
13 QtCore 0x111209a0a QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag) + 1130
14 QtCore 0x1111acf8f QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 431
15 QtCore 0x110fe836c QThread::exec() + 140
16 QtCore 0x110fe92e3 0x110fc7000 + 140003
17 libsystem_pthread.dylib 0x7ff8051364e1 _pthread_start + 125
18 libsystem_pthread.dylib 0x7ff805131f6b thread_start + 15
Thread 8:: Qt bearer thread
0 libsystem_kernel.dylib 0x7ff80510009a poll + 10
1 QtCore 0x111207f2a qt_safe_poll(pollfd*, unsigned int, timespec const*) + 90
2 QtCore 0x111209927 QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag) + 903
3 QtCore 0x1111acf8f QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 431
4 QtCore 0x110fe836c QThread::exec() + 140
5 QtCore 0x110fe92e3 0x110fc7000 + 140003
6 libsystem_pthread.dylib 0x7ff8051364e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff805131f6b thread_start + 15
Thread 9:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff805101d4a __select + 10
1 CoreFoundation 0x7ff805224659 __CFSocketManager + 641
2 libsystem_pthread.dylib 0x7ff8051364e1 _pthread_start + 125
3 libsystem_pthread.dylib 0x7ff805131f6b thread_start + 15
Thread 10:: QNetworkAccessManager thread
Thread 11:: Thread (pooled)
2 QtCore 0x110ff1e9f 0x110fc7000 + 175775
3 QtCore 0x110ff1b8e 0x110fc7000 + 174990
4 QtCore 0x110ff1acc QWaitCondition::wait(QMutex*, QDeadlineTimer) + 108
5 QtCore 0x110ff1a2e QWaitCondition::wait(QMutex*, unsigned long) + 62
6 QtCore 0x110fee467 0x110fc7000 + 160871
7 QtCore 0x110fe92e3 0x110fc7000 + 140003
8 libsystem_pthread.dylib 0x7ff8051364e1 _pthread_start + 125
9 libsystem_pthread.dylib 0x7ff805131f6b thread_start + 15
Thread 12:: com.apple.NSEventThread
5 AppKit 0x7ff807da398e _NSEventThread + 132
Thread 13:
Thread 14:
Thread 15:
Thread 7 crashed with X86 Thread State (64-bit):
rax: 0x000000010e6b23be rbx: 0x00007ff1f9713a00 rcx: 0x000000010e6b2678 rdx: 0x0000000000000048
rdi: 0x00007ff1f9713a00 rsi: 0x0000000000000008 rbp: 0x000070000bef75a0 rsp: 0x000070000bef7570
r8: 0x000000000000000a r9: 0x0000000000000000 r10: 0x000000000000000a r11: 0x0000000000000001
r12: 0x0000000000000048 r13: 0x000000000000004e r14: 0x0000000000000000 r15: 0x000000010e700410
rip: 0x000000010e6b23c5 rfl: 0x0000000000010207 cr2: 0x0000000000000000
Logical CPU: 4
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 7 instruction stream:
84 c7 01 00 00 48 8b 35-37 42 56 00 48 8b 15 28 …H.57BV.H…(
42 56 00 31 c9 e8 49 e4-07 00 48 85 c0 0f 84 a9 BV.1…I…H…
01 00 00 83 bb 90 01 00-00 01 0f 85 9c 01 00 00 …
48 89 df e8 b3 03 00 00-8b 83 90 01 00 00 89 83 H…
88 01 00 00 48 89 df be-07 00 00 00 48 83 c4 20 …H…H…
5b 41 5e 5d e9 c2 c2 ff-ff 4c 8b b3 98 01 00 00 [A^]…L…
[49]8b 3e 48 8b 07 ff 50-10 41 89 86 30 01 00 00 I.>H…P.A…0… <==
48 8b 83 98 01 00 00 c7-80 30 01 00 00 00 00 00 H…0…
00 48 8d bb 50 01 00 00-e8 4e b1 00 00 48 89 df .H…P…N…H…
e8 26 d7 ff ff 48 83 bb-78 01 00 00 00 8a 83 69 .&…H…x…i
02 00 00 0f 84 f4 01 00-00 84 c0 75 14 c6 83 69 …u…i
02 00 00 01 48 89 df be-01 00 00 00 e8 6a 04 05 …H…j…
Binary Images:
0x7ff8050f8000 - 0x7ff80512ffff libsystem_kernel.dylib () <35a199f3-e389-3202-916b-d6662a391f7e> /usr/lib/system/libsystem_kernel.dylib
0x7ff80517d000 - 0x7ff80567ffff com.apple.CoreFoundation (6.9) <70b99b27-1b5b-33c4-b401-2ecdb80f3303> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff80de7d000 - 0x7ff80e170fff com.apple.HIToolbox (2.1.1) <06fdecd6-9f69-397b-b1e2-a8226c0ba7ed> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff807bf7000 - 0x7ff808a86fff com.apple.AppKit (6.9) <1a1a9da7-da66-31da-92cd-51b9cf968145> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x110b84000 - 0x110cebfff libqcocoa.dylib () /Applications/Carbide Motion.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x110fc7000 - 0x1114fdfff org.qt-project.QtCore (5.12) <286c32b0-e13d-3600-ad17-2b6088ac2fb9> /Applications/Carbide Motion.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x10f54e000 - 0x10f98dfff org.qt-project.QtWidgets (5.12) <30358ca6-cd21-3a20-b7db-96603a913704> /Applications/Carbide Motion.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x10e3b2000 - 0x10ec15fff com.yourcompany.Carbide-Motion () <6d5a4643-cf77-3ab2-aaa0-408688bcb1e8> /Applications/Carbide Motion.app/Contents/MacOS/Carbide Motion
0x7ff805130000 - 0x7ff80513bfff libsystem_pthread.dylib () /usr/lib/system/libsystem_pthread.dylib
0x7ff805089000 - 0x7ff8050e1fff libc++.1.dylib (*) /usr/lib/libc++.1.dylib
0x10eef8000 - 0x10ef04fff org.qt-project.QtSerialPort (5.12) /Applications/Carbide Motion.app/Contents/Frameworks/QtSerialPort.framework/Versions/5/QtSerialPort
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)
Writable regions: Total=631.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=631.7M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 384K 3
Activity Tracing 256K 1
CG backing stores 2160K 4
CG image 96K 7
ColorSync 224K 26
CoreAnimation 96K 9
CoreGraphics 12K 2
CoreUI image data 1268K 8
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 226.5M 70
MALLOC guard page 32K 7
MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)
ObjC additional data 15K 1
PROTECTED_MEMORY 4K 1
STACK GUARD 56.1M 16
Stack 15.6M 16
VM_ALLOCATE 76K 17
__CTF 756 1
__DATA 36.8M 539
__DATA_CONST 31.2M 324
__DATA_DIRTY 1573K 203
__FONT_DATA 4K 1
__GLSLBUILTINS 5176K 1
__LINKEDIT 653.7M 37
__TEXT 644.6M 546
__UNICODE 592K 1
dyld private memory 1024K 1
mapped file 83.1M 27
shared memory 776K 17
TOTAL 2.1G 1889
TOTAL, minus reserved VM space 1.7G 1889
Full Report
{“app_name”:“Carbide Motion”,“timestamp”:“2023-10-30 10:43:33.00 -0500”,“app_version”:“”,“slice_uuid”:“6d5a4643-cf77-3ab2-aaa0-408688bcb1e8”,“build_version”:“”,“platform”:1,“bundleID”:“com.yourcompany.Carbide-Motion”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.6.6 (21G646)”,“incident_id”:“18839F30-CFD6-4613-A45B-27A1123CEFD7”,“name”:“Carbide Motion”}
“uptime” : 850000,
“procLaunch” : “2023-10-30 10:43:20.0215 -0500”,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro15,2”,
“procStartAbsTime” : 851641911204552,
“coalitionID” : 6958,
“osVersion” : {
“train” : “macOS 12.6.6”,
“build” : “21G646”,
“releaseType” : “User”
“captureTime” : “2023-10-30 10:43:32.8246 -0500”,
“incident” : “18839F30-CFD6-4613-A45B-27A1123CEFD7”,
“bug_type” : “309”,
“pid” : 71758,
“procExitAbsTime” : 851654708858664,
“cpuType” : “X86-64”,
“procName” : “Carbide Motion”,
“procPath” : “/Applications/Carbide Motion.app/Contents/MacOS/Carbide Motion”,
“bundleInfo” : {“CFBundleIdentifier”:“com.yourcompany.Carbide-Motion”},
“storeInfo” : {“deviceIdentifierForVendor”:“431D0D88-90E7-5238-9741-C75FC0237B40”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.yourcompany.Carbide-Motion”,
“crashReporterKey” : “D024178D-EE51-6659-7269-E84BD268B20C”,
“wakeTime” : 420,
“bridgeVersion” : {“build”:“20P5058”,“train”:“7.5”},
“sleepWakeUUID” : “8DF43B07-260D-49C8-8FC8-64EC9E3CBF42”,
“sip” : “enabled”,
“vmRegionInfo” : “0 is not in any region. Bytes before following region: 4533723136\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n—> \n __TEXT 10e3b2000-10ec16000 [ 8592K] r-x/r-x SM=COW …arbide Motion”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x0000000000000000”,“rawCodes”:[1,0],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGSEGV”,“subtype”:“KERN_INVALID_ADDRESS at 0x0000000000000000”},
“termination” : {“flags”:0,“code”:11,“namespace”:“SIGNAL”,“indicator”:“Segmentation fault: 11”,“byProc”:“exc handler”,“byPid”:71758},
“vmregioninfo” : “0 is not in any region. Bytes before following region: 4533723136\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n—> \n __TEXT 10e3b2000-10ec16000 [ 8592K] r-x/r-x SM=COW …arbide Motion”,
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 7,
“threads” : [{“id”:4942183,“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:6506,“symbol”:“mach_msg_trap”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:7384,“symbol”:“mach_msg”,“symbolLocation”:56,“imageIndex”:0},{“imageOffset”:525133,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:319,“imageIndex”:1},{“imageOffset”:518616,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1276,“imageIndex”:1},{“imageOffset”:515612,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:562,“imageIndex”:1},{“imageOffset”:189926,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:2},{“imageOffset”:189258,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:594,“imageIndex”:2},{“imageOffset”:188645,“symbol”:“_BlockUntilNextEventMatchingListInModeWithFilter”,“symbolLocation”:70,“imageIndex”:2},{“imageOffset”:257901,“symbol”:“_DPSNextEvent”,“symbolLocation”:927,“imageIndex”:3},{“imageOffset”:251434,“symbol”:“-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:1394,“imageIndex”:3},{“imageOffset”:221038,“imageIndex”:4},{“imageOffset”:1990543,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:431,“imageIndex”:5},{“imageOffset”:2152398,“symbol”:“QDialog::exec()”,“symbolLocation”:526,“imageIndex”:6},{“imageOffset”:2914636,“symbol”:“MainWindow::onError(QString)”,“symbolLocation”:124,“imageIndex”:7},{“imageOffset”:2949341,“imageIndex”:7},{“imageOffset”:2180033,“symbol”:“QObject::event(QEvent*)”,“symbolLocation”:753,“imageIndex”:5},{“imageOffset”:316074,“symbol”:“QWidget::event(QEvent*)”,“symbolLocation”:4826,“imageIndex”:6},{“imageOffset”:1432197,“symbol”:“QMainWindow::event(QEvent*)”,“symbolLocation”:277,“imageIndex”:6},{“imageOffset”:67165,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:269,“imageIndex”:6},{“imageOffset”:72193,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:497,“imageIndex”:6},{“imageOffset”:2009508,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:212,“imageIndex”:5},{“imageOffset”:2014174,“symbol”:“QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*)”,“symbolLocation”:878,“imageIndex”:5},{“imageOffset”:224025,“imageIndex”:4},{“imageOffset”:225928,“imageIndex”:4},{“imageOffset”:524635,“symbol”:“CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION”,“symbolLocation”:17,“imageIndex”:1},{“imageOffset”:524483,“symbol”:“__CFRunLoopDoSource0”,“symbolLocation”:180,“imageIndex”:1},{“imageOffset”:523837,“symbol”:“__CFRunLoopDoSources0”,“symbolLocation”:242,“imageIndex”:1},{“imageOffset”:518232,“symbol”:“__CFRunLoopRun”,“symbolLocation”:892,“imageIndex”:1},{“imageOffset”:515612,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:562,“imageIndex”:1},{“imageOffset”:189926,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:2},{“imageOffset”:189258,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:594,“imageIndex”:2},{“imageOffset”:188645,“symbol”:“_BlockUntilNextEventMatchingListInModeWithFilter”,“symbolLocation”:70,“imageIndex”:2},{“imageOffset”:257901,“symbol”:“_DPSNextEvent”,“symbolLocation”:927,“imageIndex”:3},{“imageOffset”:251434,“symbol”:“-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:1394,“imageIndex”:3},{“imageOffset”:195801,“symbol”:“-[NSApplication run]”,“symbolLocation”:586,“imageIndex”:3},{“imageOffset”:221187,“imageIndex”:4},{“imageOffset”:1990543,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:431,“imageIndex”:5},{“imageOffset”:2011058,“symbol”:“QCoreApplication::exec()”,“symbolLocation”:130,“imageIndex”:5},{“imageOffset”:2840293,“symbol”:“main”,“symbolLocation”:5157,“imageIndex”:7},{“imageOffset”:42308,“symbol”:“start”,“symbolLocation”:52,“imageIndex”:7}]},{“id”:4942209,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:4942210,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:4942222,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:4942224,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:4942238,“frames”:[{“imageOffset”:8008,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:8}]},{“id”:4942242,“frames”:[{“imageOffset”:17370,“symbol”:“__psynch_cvwait”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:“_pthread_cond_wait”,“symbolLocation”:1249,“imageIndex”:8},{“imageOffset”:48563,“symbol”:“std::__1::condition_variable::__do_timed_wait(std::__1::unique_lockstd::__1::mutex&, std::__1::chrono::time_point<std::__1::chrono::system_clock, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > >)”,“symbolLocation”:93,“imageIndex”:9},{“imageOffset”:2850830,“imageIndex”:7},{“imageOffset”:2850589,“imageIndex”:7},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“triggered”:true,“id”:4942243,“instructionState”:{“instructionStream”:{“bytes”:[132,199,1,0,0,72,139,53,55,66,86,0,72,139,21,40,66,86,0,49,201,232,73,228,7,0,72,133,192,15,132,169,1,0,0,131,187,144,1,0,0,1,15,133,156,1,0,0,72,137,223,232,179,3,0,0,139,131,144,1,0,0,137,131,136,1,0,0,72,137,223,190,7,0,0,0,72,131,196,32,91,65,94,93,233,194,194,255,255,76,139,179,152,1,0,0,73,139,62,72,139,7,255,80,16,65,137,134,48,1,0,0,72,139,131,152,1,0,0,199,128,48,1,0,0,0,0,0,0,72,141,187,80,1,0,0,232,78,177,0,0,72,137,223,232,38,215,255,255,72,131,187,120,1,0,0,0,138,131,105,2,0,0,15,132,244,1,0,0,132,192,117,20,198,131,105,2,0,0,1,72,137,223,190,1,0,0,0,232,106,4,5],“offset”:96}},“name”:“Machine Thread”,“threadState”:{“r13”:{“value”:78},“rax”:{“value”:4536869822,“symbolLocation”:270,“symbol”:“MachineController::onGrblCycleChanged(Grbl::cycle_type)”},“rflags”:{“value”:66055},“cpu”:{“value”:4},“r14”:{“value”:0},“rsi”:{“value”:8},“r8”:{“value”:10},“cr2”:{“value”:0},“rdx”:{“value”:72},“r10”:{“value”:10},“r9”:{“value”:0},“r15”:{“value”:4537189392},“rbx”:{“value”:140677248793088},“trap”:{“value”:14,“description”:“(no mapping for user data read)”},“err”:{“value”:4},“r11”:{“value”:1},“rip”:{“value”:4536869829,“matchesCrashFrame”:1},“rbp”:{“value”:123145502553504},“rsp”:{“value”:123145502553456},“r12”:{“value”:72},“rcx”:{“value”:4536870520,“symbolLocation”:968,“symbol”:“MachineController::onGrblCycleChanged(Grbl::cycle_type)”},“flavor”:“x86_THREAD_STATE”,“rdi”:{“value”:140677248793088}},“frames”:[{“imageOffset”:3146693,“symbol”:“MachineController::onGrblCycleChanged(Grbl::cycle_type)”,“symbolLocation”:277,“imageIndex”:7},{“imageOffset”:2211084,“symbol”:“QMetaObject::activate(QObject*, int, int, void**)”,“symbolLocation”:3132,“imageIndex”:5},{“imageOffset”:3480286,“symbol”:“Grbl::cycleChanged(Grbl::cycle_type)”,“symbolLocation”:62,“imageIndex”:7},{“imageOffset”:3102956,“symbol”:“Grbl::processLine(std::__1::basic_string<char, std::__1::char_traits, std::__1::allocator >)”,“symbolLocation”:7484,“imageIndex”:7},{“imageOffset”:3095290,“symbol”:“Grbl::processBuffer()”,“symbolLocation”:314,“imageIndex”:7},{“imageOffset”:3088113,“symbol”:“Grbl::serialDataReady()”,“symbolLocation”:177,“imageIndex”:7},{“imageOffset”:2210171,“symbol”:“QMetaObject::activate(QObject*, int, int, void**)”,“symbolLocation”:2219,“imageIndex”:5},{“imageOffset”:33167,“imageIndex”:10},{“imageOffset”:42790,“imageIndex”:10},{“imageOffset”:67165,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:269,“imageIndex”:6},{“imageOffset”:72193,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:497,“imageIndex”:6},{“imageOffset”:2009508,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:212,“imageIndex”:5},{“imageOffset”:2366883,“symbol”:“QEventDispatcherUNIXPrivate::activateSocketNotifiers()”,“symbolLocation”:99,“imageIndex”:5},{“imageOffset”:2370058,“symbol”:“QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:1130,“imageIndex”:5},{“imageOffset”:1990543,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:431,“imageIndex”:5},{“imageOffset”:136044,“symbol”:“QThread::exec()”,“symbolLocation”:140,“imageIndex”:5},{“imageOffset”:140003,“imageIndex”:5},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:4942244,“name”:“Qt bearer thread”,“frames”:[{“imageOffset”:32922,“symbol”:“poll”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:2363178,“symbol”:“qt_safe_poll(pollfd*, unsigned int, timespec const*)”,“symbolLocation”:90,“imageIndex”:5},{“imageOffset”:2369831,“symbol”:“QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:903,“imageIndex”:5},{“imageOffset”:1990543,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:431,“imageIndex”:5},{“imageOffset”:136044,“symbol”:“QThread::exec()”,“symbolLocation”:140,“imageIndex”:5},{“imageOffset”:140003,“imageIndex”:5},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:4942249,“name”:“com.apple.CFSocket.private”,“frames”:[{“imageOffset”:40266,“symbol”:“__select”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:685657,“symbol”:“__CFSocketManager”,“symbolLocation”:641,“imageIndex”:1},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:4942258,“name”:“QNetworkAccessManager thread”,“frames”:[{“imageOffset”:32922,“symbol”:“poll”,“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:2363178,“symbol”:“qt_safe_poll(pollfd*, unsigned int, timespec const*)”,“symbolLocation”:90,“imageIndex”:5},{“imageOffset”:2369831,“symbol”:“QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:903,“imageIndex”:5},{“imageOffset”:1990543,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:431,“imageIndex”:5},{“imageOffset”:136044,“symbol”:“QThread::exec()”,“symbolLocation”:140,“imageIndex”:5},{“imageOffset”:140003,“imageIndex”:5},{“imageOffset”:25825,“symbol”:“_pthread_start”,“symbolLocation”:125,“imageIndex”:8},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:8}]},{“id”:4942259,“name”:“Thread (pooled)”,“frames”:[{“imageOffset”:17370,“symbol”:"_psynch_cvwait",“symbolLocation”:10,“imageIndex”:0},{“imageOffset”:27247,“symbol”:"
