I have a Shapeoko 3 XXL. The router has become not-perpendicular via loosened v-wheels/eccentric nuts. Those were snugged.
The eccentric nuts on the Y1/Y2 axis are either too tight and the gantry won’t move or too loose to create a forward leaning router. The Y2 top rear (towards back of machine) V-wheel is loose enough to spin freely.
I have a 3XXL as well and my experience with what your described is you need to replace the v-wheels. At minimum “The Y2 top rear (towards back of machine) V-wheel is loose enough to spin freely.”
The top ones on the Y rails of my machine have also been worn by rubbing against the belt tensioners on the front and back of the y rails. (Due to them being out of alignment)
I have had to replace these in occassion as they just wear out. I can never really eyeball it and see the wear but can “feel” it when i replace them. Hope this helps!
