https://carbide3d.com/3d-print/spindle-hose-mount/
The two links are no longer valid. @Luke
Here’s the STL file for the 65mm hose mount if that helps.
65mmspindlehosemount25.stl (746.2 KB)
I finally printed this but it’s not the same one as shown on their page. There is no way to clamp the holder onto the spindle so it has no rigidity to hold up to the movement. Appreciate you helping though!
Anyone else have a copy of these since the links are still doa?
You’re right, the picture has the added clamping feature. That was newly added since the original version I printed. I used some VHB tape to hold mine in place on the VFD spindle, not ideal but it does keep the dust collection hose mostly out of the way. The clamping add on seems like a good idea. I wonder why the files aren’t available.
Ah not a bad quick fix, I might follow suit.
The files are linking to step files which I don’t think I’ve seen them post before. Might just be a wrong url but I can’t suss out the right one if it’s there. ![]()
80mmHoseMount.stl (1.2 MB)
65mmHoseMount.stl (1.2 MB)
Looking into the issue on the site.
