When working with toolpath, is it possible have some kind of section that provide some default bits we could choose. Most of us always work with same tools.
This should reduce the time we spend to get a tool or change a tool :
- Edit tool tool button
- Select tool button
- Find the tool you want in the list
- Click OK 2 times
As an example: this is very slow if you want to change your 1/4 end mills to 1/8 to esitmate the impact on the CNC workig time ou sur la qualité de la finition.
