Why are there little holes around my 3D carvinga?
What design software are you using? If it’s Carbide Create, post the design file so we can look at it.
Yes, Carbide create Pro. I will hop on my computer later and post it. Thanks ![]()
If the 3D model only goes to that edge, and you use the outline vector right on the edge, portions of the vector may fall outside the 3D model, and the cutter dives down to the table or bottom of part because there’s nothing to stop it.
Add a flat component the same height as your part or just slightly lower to provide ‘runoff’ for the tool.
Thanks Tod!!! Ill give this a try and let you guys know how it goes.
