Location of Air Assist Mounting Block with 80mm Spindle
Hi, I’m upgrading from 65mm Spindle to the 80mm Spindle. Since the 80mm Spindle Mount uses the Air Assist mounting holes, where/how should I mount the Air Assist Mounting Block? Is there a new 3D Printed Air Assist Mounting Block Design to use with the 80mm Spindle?
Thanks
Matt
My 80mm mount (HDM) has holes on the side of the spindle mount where I mounted the mist mixer.
Looks like the new mount has holes on one side & the dovetail mount on the other side.
Thanks. I’ll have to design a new mount or MacGyver the 5 Pro one I have.
My understanding is the the “accessory mount” (the dovetail that @Tod1d mentioned) is the same between the 65mm and the 80mm mount so if you are using that it should be a drop in replacement.
Thanks for the info. I been using a 3D printed mount I got off Cutrocket. I just found the plate that fits the dovetail on Carbide3d. I may try the Cutrocket bracket for the HDM also.
