Hi everyone,need some help,where is the best place to get extra long end mills,201 and 102 equivalent.Any specific code numbers would be great.
Thanks so much
I’m not sure how long “extra long” is, but these guys have long cut end mills. I’ve purchased from them in the past, and the quality is good and price reasonable for USA-made carbide tools.
I recently cut a lot of 1.5 inch material and had a Melin tool with a 1.5 inch cutting depth. The end mill worked very well in the wet treated pine material is is still very sharp. I can recommend it. Here is the specs and part number.
Melin AMG-808-E .250 Flat Cutter 1.5” Cut Length 4” OAL 1/4” Shank
Hi Guy that is exactly what I want to do,pine but ar 33 mm.
I calculated 33mm to be 1 5/16 inch so the Melin would work. You can cut deeper than cutting length but you can burn near the top with the bit rubbing.
