I’m cutting this pocket using the 0.25" Amana 46202-K Downcut 0.125" 46225-K Downcut tools.
I’m using 3D Adaptive Clearing and there seems to be a large amount of time sent in milling the circular hole on the left side of the pocket. I tried a boring operation but that left a cylinder in the center of the pocket.
Here are the settings for the first operation:
Any thoughts would be appreciated.
Thanks,
kelaa
(kelaa)
January 23, 2022, 7:18pm
2
If you want to continue to use Bore, you can manually increase the number of stepovers until it removes the core:
@kelaa Thanks for the tip, I didn’t see that option.
I just switched from 3D adaptive to 3D pocket with feed optimization enabled and that has reduced the time to 10 min operation with the tool change.
system
(system)
Closed
February 2, 2022, 6:30pm
4
This topic was automatically closed after 10 days. New replies are no longer allowed.
