Carving into 6061 aluminum, need to go approximately 1mm deep. Extreme detail work - lots of small lines which are very close to each other. I’m wondering what tooling would be best for this task, here’s what I’m considering:
1/32" end mill Amazon.ca
aggressive vbit Amazon.ca
What would you guys use?
WillAdams
(William Adams (Carbide 3D))
August 20, 2023, 11:42am
2
The #501 and #502 engravers seem well-suited to this sort of work.
How deep can they push into the aluminum?
Also what’s the difference between the spring loaded engraver and a solid one?
SDGuy
(Anthony)
August 21, 2023, 1:45pm
4
You could also try a Drag bit.
MC Etcher is our new diamond drag bit. It is perfect for fine line engraving on composites, metals, and glass. MC Etcher drags a diamond-coated, spring-loaded tip over the surface of your material to create an etched or engraved pattern, it does not...
Price: USD 40.00
MicSquared
(Mike Michaelson)
August 21, 2023, 6:38pm
5
I don’t think the drag tool will go that deep though…
system
(system)
Closed
September 20, 2023, 6:38pm
6
