Loose housing issue
On my last cut i notice my router rotating i checked and the set screw was missing. So i found the spare and installed it. Then i noticed the housing was a bit shaky I checked all screw / bolts on the plate and V wheels. Everything seems tight. The bottom seems to move.
For some reason I’m having an issue uploading a video from my phone.
The grub screw on the router mount is only intended to be used if the mount is too tight to admit a router — it allows opening it up — once the router is installed, it should be removed if it was needed.
I don’t believe videos can be posted here — instead, post to a video sharing site and post a link, or post photos here, or send the video in to support@carbide3d.com
Ah. Okay great i sent the email with pictures and video.
