I will note that the pricing is a bit more stable if you can purchase directly from a sawmill — well worth looking one up — or, if you’re in a suitable locale w/ a suitable yard and so forth, get a chainsaw mill.
Yep, it’s been a bit frustrating while trying to use “cheap” 2x4x8’s and realizing I should look at other less expensive materials or scavenge what I can from leftover remodel projects.
However, it seems that prices are coming down for consumers. Over the last 6 weeks I’ve seen 2x4x8 prices go from $12.50 down to $9! Here’s to hoping we can get under $6 before the end of the summer.
Interestingly True Baltic Birch plywood (5’ x 5’ sheets) has not gone up in price. Neither have hardwoods. It is construction grade materials that have seen the increase.
Galvanized fence posts and True Baltic Birch - may start a new trend
I have a good stock of hardwoods so I have not been shooping lately for hardwood.
Any ideas for recycling of wood for our uses?
I used to have a Habit for Humanity Restore store but they closed. I bought quite a bit of hardwood in there. I keep my eye on craigslist but have not had any luck lately.
And am I taking crazy pills or did 12/2 wire always cost $2/ft? I just need a 6" piece for a pigtail and the lowest price I can get is $28 for a 15ft length of Romex.
