Aloha!!
Does anyone know if Mach 3 work with Carbide 3D?
I am using MeshCAM 6 with my Carbide 3D and it takes forever to do “calculate setup”.
Thank you!
Aloha!!
Thank you!
Mach 3 is a machine controller usually used with breakout boards attached to parallel ports. I don’t believe it’s intended for use with machines running a subset of G-Code on an independent controller attached over USB.
I believe MeshCAM has markedly improved since v6 — update?
Thank you Will.
No, I have not done a MeshCAM update.
Is it a normal thing for MeshCAM to take a long time to calculate the setup?
Depending on the complexity of the file it may be. You should contact support@grzsoftware.com for more information, also to check on the licensing involved in updating.
I just emailed them. I will check on the licensing. Thank you very much
