Machinable ceramic on a Nomad?
Greetings!
I am absolutely loving my Nomad 3 and am slowly learning how to use it. Now, I need to make some of these gear-looking things. I’ve pretty much finalized the size and shape using 1/4" thick PVC.
Now I would like to cut these out of machinable ceramic, like this one: McMaster-Carr
Any tips/tricks for me? Feeds and speeds, special cutters, etc. Thank you!
Greg
Interesting material, that I don’t think I have seen mentioned here before.
Out of curiosity I googled feeds and speeds for Macor, and the first few links had this to say:
This one
Using carbide tooling: Cutting speed = 9-15 m/min (30-50 sfm). Feed Rate = 0.005-0.013 cm/rev (.002-.005 ipr)Depth of cut = 0.38-0.65 cm(.150-.200 in).
This other one
Cutting Speed 1 to 1.4 m/min (20 to 35 sfpm)
Feedrate .05mm/tooth (.002"/tooth)
Depth of cut 3 to 5 mm (.125"to .200")
Tool Suggestions:
Carbide C2 or equivalent recommended for improved life.
Two or four flute cutters work well.
Do not use chipbreaker or roughing mills.
Standard helix milling cutters work well.
This third one
A cutting speed of 20 to 35 surface FPM and a chip load per tooth of .002″, with a depth of cut of .150″ to .250″, is generally acceptable.
So the good news is that a 2-flute Carbide endmill should be the right tool, and you sure have some of those.
The consensus seems to be to use around 30sfm, which on a 1/8" endmill is…916 RPM. I’m not a Nomad person but this sounds like the extreme low end of the RPM range.
And then to match their recommended 0.002" chipload, that would translate on a 2-flute 1/8" endmill to a feedrate of 0.002 * 2 * 920 = 3.7ipm…slooooooow (which seems to be the consensus too, but it might take a long while to mill large/thick pieces)
Cutting depths, I would most definitely not use those 0.25" recommendations, but start very shallow (25% of the cutter diameter) and increase it experimentally.
You would also probably need to use coolant. Lots of it.
Please consider all of this as pure “thinking out loud” from someone who NEVER cut Macor before (so it may be complete BS, this is just how I would approach this beast one day one). Hopefully some who actually successfully milled that material before will chime in.
That’s well out of the working range of the Nomad. It can go that low but I remember that only being okay for edge finders, not for cutting.
I think I’d just conclude that this is a material the Nomad can’t cut, at least with its stock spindle.
And then again I remember passionate threads about whether SFM targets should be taken for granted / are really applicable as is on a Shapeoko/Nomad. One could be adventurous and try at whatever the minimum workable RPM of the Nomad is.
OK, so I’m not a machinist… I’m a biomedical engineer. (means I know alot about something very obscure). I do remember machining Macor by hand many years ago and it was cutting more like butter than aluminum…
Let’s try this! :slight_smile:
Is there some less expensive material which is known to machine similarly which you could do test cuts in?
Ages ago, we were looking at that on the Shapeoko forums, but there were very few pairs which seemed to prove out for similar feeds and speeds.
I seem to recall my nomad needing a value of 1000? I was troubleshooting a thing with support a while ago. I’ll have to check it again when I get back later today.
@WillAdams, I need a good dielectric that is also corrosion resistant. Teflon would be good, I suppose, but it doesn’t machine all that well… Any ideas for me? :slight_smile:
I think Unobtainium would be a good choice, though it is hard to find.
HDPE would be too soft (mechanically) I presume ? HDPE is my favorite butter to scoop mill through.
For material, perhaps Delrin?
In discussion on team chat one concern was dust control — any which escapes would cause unanticipated wear.
If Delrin works for you then no common plastic will machine better. Delrin is my favorite plastic to work with by far.
@robgrz, @WillAdams
Delrin looks very good. I’ve never worked with it but reading material properties on McMaster… Looks like it’s worth a try.
Should I keep same feeds and speeds as HDPE?
@Julien, HDPE is not that good with UV and ozone… my cup of tea… I like Delrin’s description better :slight_smile:
I’m sure @wmoy will jump in and correct me but Delrin is very forgiving so you can cut it just like any other plastic and adjust from there.
@Julien, I stand corrected. Looks like UHMWPE fibers are good for my applications. I’ll try PE and acetal.
Also, WAY cheaper than ceramic :slight_smile:
Still, other applications require thermal resistance. I’m sure Macor is going to happen one day :slight_smile:
