Machine Error switch
Hello,
I opened the back of my nomad 3D and I had a problem. When I tried to initialize the machine and I heard a huge noise coming from the nomad and an error appeared: Machine controller restarded unexpectedelly and may be in an undefined state. I think there’s a problem with the x switch since the LED turned blue ?
I’ve had my Nomad hit physical stops a couple times. What has worked for me is to power off the mill, rotate the lead screws by hand away from the hard stop by a couple rotations, then power up and initialize the mill.
I’ve been having the same issue and the Y-axis limit switch failed.
It got better after the limit switch was replaced.
Thank you so much ! I still have a small problem with it though…
