I have a Shapeoko Pro XL. The limits on this machine are 33(X) 17.5(Y) 4(Z).
I’ve had this machine for 4 years and I just noticed something that has me confused.
First, everything is working fine, it Initializes correctly and cuts correctly.
Here’ my confusion. After i initialize the machine if i use Rapid Position to move the carriage to N S E or W it moves the carriage to that position. But then if i use the jog button i can move the carriage further in that direction.
Example: I click on Rapid Position S and the carriage moves to the front center of the machine. But then if i go to jog i can move the carriage another 2 1/2 inches toward the front of the machine. The same thing happens if i use N W or E although the distance i can jog from the the Rapid position is not as great. Maybe .5 inch.
So my question is. Is the limits of the machine the position its at when i use rapid position or the position its at when i jog to the max distance.
I hope i explained that well. And like i said my machine is working fine.
