Hello,
I would appreciate your support with the following situation.
I zero and savie the X / Y position but when I run the ‘job’, the machine is not positioned in the X and Y position that was saved.
I am also noticing that when the machine goes to the Bit Zetter, the same situation happens, the bit is not always positioned in the same spot.
Please see the attached picture. The ‘+’ mark at the left is where I saved the X/Y position. When I ran the job, the machine positioned 1/4" to the left; not exactly where the X/Y was saved.
Can you please let me know how to fix this? I need to solve it ASAP as I need to perform 2-sided machining.
