Phew!! Finally, that did it. Now Rapid positioning is working. Thanks Jorge for your help.
Hi,
I received my nomad today and I ot this message too. Tried to enter $# as suggested anf then /G10L2P6X-123.815Y-107.850Z-127.000 but nothing seems to happen when I lick send on either occassion. Can someone help please?
Could you please go through step-by-step:
- what you did (and on the basis of what documentation)
- what you expected to happen
- what actually happened
I am going through set up.
- connect usb
2.power up nomad - start up carbide motion
- connect cutter
- load 1st tutorial (wrench)
- Click Jog
- Begin homing
- Click to measure tool
- Machine parameters invalid message displayed
If I try and move the cutter to the lower left-hand corner of the stock, I can only job the machine a few moves and then it stops responding.
I searched the forum for previous issues and it was suggested that I go to MDI>$# and send to check G59 value and then cut and paste /G10L2P6X-123.815Y-107.850Z-127.000and send. nothing happens when I click send either time
@WillAdams
Thanks
Eve
Very disappointed here. Can support please come back to me please? So far I havenāt been able to start the first tutorial!
Support is on Midwest / Chicago time ā please contact support@carbide3d.com to get in the official support queue ā hopefully someone will be able to get back to you.
In the meanwhile you could check your machine setup against the typical Nomad defaults (which Iām afraid I canāt find a link for) ā any documentation on this included w/ your machine?
Yes, I have emailed, thank you. Not a lot of documentation Iām afraid. How would I go about changing G28? Any ideas?
@vauxleather, like will said email support@, but in the mean time type /G10L2P5X553Y883Z-106.000
Then check the log that G58 now has values populated. This should get you going.
@Jorge Thank you! Thats fixed it!
@Jorge
Well, it fixed the invalid parameter issue but now I cannot start the job./ā¦
For documentation on G-code please see: http://www.shapeoko.com/wiki/index.php/G-Code ā we do have a basic page on the Nomad on the wiki: http://www.shapeoko.com/wiki/index.php/Nomad_883
I suspect that the defaults on your machine arenāt set right ā if you could find the proper ones for the Nomad, then compare them to your machineās current settings and then update them appropriately, Iām sure things would then ājust workā.
So I got past the invalid parameters problem, now the machine will start the wrench tutorial job and stop half way through or maybe not even start, like theres a com issue. When it stops the spindle is still spinning, it just stops moving through.
Electronic disconnects have been a significant percentage of the problems which have been reported. Recommendations from the Shapeoko side of the house here: http://www.shapeoko.com/wiki/index.php/Electronics#Recommendations
Please try the solutions which you feel apply to the Nomad and which you are comfortable doing ā if they donāt work, contact support@carbide3d.com and let them know what youāve tried and they will be able to work w/ you to puzzle out the specifics of your situation and the solution for your machine and environs.
Here it stopped at line 12:
Test Waitingā¦
<Idle,MPos:0.000,0.000,0.000,WPos:0.000,0.000,0.000,Buf:0,RX:0,Ln:0,F:0.>
SET MACHINE STATE: RUNNING
gc_clear_optional_block_skip
gc_wait_for_idle
___________N0 G4P0.005 ___________
ok
gc_sync
gc_parser_state
___________$G ___________
[G0 G54 G17 G21 G90 G94 M0 M5 M9 T0 F0. S0.]
ok
gc_spindle
___________M05 ___________
gc_wait_for_idle
gc_homing
___________$h ___________
<Idle,MPos:0.000,0.000,0.000,WPos:0.000,0.000,0.000,Buf:1,RX:0,Ln:-1,F:0.>
<Run,MPos:0.000,0.000,-2.100,WPos:0.000,0.000,-2.100,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:0.000,0.000,-4.990,WPos:0.000,0.000,-4.990,Buf:0,RX:0,Ln:0,F:28.>
<Idle,MPos:0.000,0.000,-5.000,WPos:0.000,0.000,-5.000,Buf:1,RX:0,Ln:-1,F:0.>
<Run,MPos:-0.280,-0.280,-5.000,WPos:-0.280,-0.280,-5.000,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:-2.630,-2.630,-5.000,WPos:-2.630,-2.630,-5.000,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:-4.930,-4.930,-5.000,WPos:-4.930,-4.930,-5.000,Buf:0,RX:0,Ln:0,F:181.>
ok
<Idle,MPos:-5.000,-5.000,-5.000,WPos:-5.000,-5.000,-5.000,Buf:0,RX:0,Ln:0,F:0.>
gc_wait_for_idle
ok
gc_sync
gc_comment
gc_comment
gc_comment
gc_comment
gc_comment
gc_comment
gc_wait_for_idle
___________N3 G4P0.005 ___________
ok
gc_units(INCH)
gc_wait_for_idle
___________N4 G4P0.005 ___________
gc_distance_mode(ABSOLUTE)
gc_simulation_tool
gc_comment
gc_comment
gc_spindle
gc_dwell
___________N6 G4P2 ___________
ok
gc_comment
gc_motion
___________N6G0Z-5.000 ___________
gc_motion
___________N6G0X-120.000 ___________
gc_wait_for_idle
___________N6 G4P0.005 ___________
<Run,MPos:-5.665,-5.000,-5.000,WPos:-5.665,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:1944.>
<Run,MPos:-13.230,-5.000,-5.000,WPos:-13.230,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-21.925,-5.000,-5.000,WPos:-21.925,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-30.530,-5.000,-5.000,WPos:-30.530,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-39.230,-5.000,-5.000,WPos:-39.230,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-47.845,-5.000,-5.000,WPos:-47.845,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-56.565,-5.000,-5.000,WPos:-56.565,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-65.170,-5.000,-5.000,WPos:-65.170,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-73.865,-5.000,-5.000,WPos:-73.865,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-82.490,-5.000,-5.000,WPos:-82.490,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-91.360,-5.000,-5.000,WPos:-91.360,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-99.810,-5.000,-5.000,WPos:-99.810,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-108.485,-5.000,-5.000,WPos:-108.485,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-117.225,-5.000,-5.000,WPos:-117.225,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:1528.>
ok
<Idle,MPos:-120.000,-5.000,-5.000,WPos:-120.000,-5.000,-5.000,Buf:0,RX:0,Ln:0,F:0.>
gc_tool
SET MACHINE STATE: WAIT_FOR_PAUSE
gc_cancel_tool_length
gc_wait_for_idle
ok
SET MACHINE STATE: PAUSED
gc_spindle
ok
gc_motion
gc_motion
___________N6G0X-2.500Z-5.000 ___________
gc_motion
___________N6G0Z-35.000 ___________
gc_do_tool_probe
___________N6G38.2Z-105.000F800.0 ___________
<Run,MPos:-117.025,-5.000,-5.000,WPos:-117.025,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-108.345,-5.000,-5.000,WPos:-108.345,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-99.755,-5.000,-5.000,WPos:-99.755,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-91.030,-5.000,-5.000,WPos:-91.030,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-82.400,-5.000,-5.000,WPos:-82.400,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-73.740,-5.000,-5.000,WPos:-73.740,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-65.135,-5.000,-5.000,WPos:-65.135,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-56.420,-5.000,-5.000,WPos:-56.420,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-47.810,-5.000,-5.000,WPos:-47.810,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-39.080,-5.000,-5.000,WPos:-39.080,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-30.490,-5.000,-5.000,WPos:-30.490,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-21.790,-5.000,-5.000,WPos:-21.790,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-13.190,-5.000,-5.000,WPos:-13.190,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-4.645,-5.000,-5.000,WPos:-4.645,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:1338.>
<Run,MPos:-2.500,-5.000,-6.240,WPos:-2.500,-5.000,-6.240,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-10.510,WPos:-2.500,-5.000,-10.510,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-14.710,WPos:-2.500,-5.000,-14.710,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-18.965,WPos:-2.500,-5.000,-18.965,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-23.165,WPos:-2.500,-5.000,-23.165,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-27.455,WPos:-2.500,-5.000,-27.455,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-31.625,WPos:-2.500,-5.000,-31.625,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-35.000,WPos:-2.500,-5.000,-35.000,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-37.325,WPos:-2.500,-5.000,-37.325,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-40.010,WPos:-2.500,-5.000,-40.010,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-42.670,WPos:-2.500,-5.000,-42.670,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-45.345,WPos:-2.500,-5.000,-45.345,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-47.985,WPos:-2.500,-5.000,-47.985,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-50.675,WPos:-2.500,-5.000,-50.675,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-53.330,WPos:-2.500,-5.000,-53.330,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-55.995,WPos:-2.500,-5.000,-55.995,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-58.655,WPos:-2.500,-5.000,-58.655,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-61.340,WPos:-2.500,-5.000,-61.340,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-63.985,WPos:-2.500,-5.000,-63.985,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-66.650,WPos:-2.500,-5.000,-66.650,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-69.330,WPos:-2.500,-5.000,-69.330,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-71.970,WPos:-2.500,-5.000,-71.970,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-74.650,WPos:-2.500,-5.000,-74.650,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-77.320,WPos:-2.500,-5.000,-77.320,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-79.975,WPos:-2.500,-5.000,-79.975,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-82.655,WPos:-2.500,-5.000,-82.655,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-85.305,WPos:-2.500,-5.000,-85.305,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-87.980,WPos:-2.500,-5.000,-87.980,Buf:1,RX:0,Ln:6,F:476.>
[PRB:-2.500,-5.000,-87.730:1]
ok
<Idle,MPos:-2.500,-5.000,-88.600,WPos:-2.500,-5.000,-88.600,Buf:0,RX:0,Ln:0,F:0.>
gc_wait_for_idle
ok
gc_sync
gc_distance_mode(INCREMENTAL)
gc_motion
___________N6G0Z-85.600 ___________
ok
gc_do_tool_probe
___________N6G38.2Z-188.600F200.0 ___________
<Run,MPos:-2.500,-5.000,-85.780,WPos:-2.500,-5.000,-85.780,Buf:0,RX:0,Ln:0,F:2.>
<Run,MPos:-2.500,-5.000,-86.120,WPos:-2.500,-5.000,-86.120,Buf:1,RX:0,Ln:6,F:200.>
<Run,MPos:-2.500,-5.000,-86.785,WPos:-2.500,-5.000,-86.785,Buf:1,RX:0,Ln:6,F:200.>
<Run,MPos:-2.500,-5.000,-87.460,WPos:-2.500,-5.000,-87.460,Buf:1,RX:0,Ln:6,F:200.>
[PRB:-2.500,-5.000,-87.725:1]
ok
<Idle,MPos:-2.500,-5.000,-87.895,WPos:-2.500,-5.000,-87.895,Buf:0,RX:0,Ln:0,F:0.>
gc_wait_for_idle
ok
gc_sync
gc_motion
ok
gc_motion
___________N6G0X-8.000 ___________
gc_apply_reference_tool
gc_wait_for_idle
<Run,MPos:-2.500,-5.000,-84.860,WPos:-2.500,-5.000,-84.860,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-80.610,WPos:-2.500,-5.000,-80.610,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-76.395,WPos:-2.500,-5.000,-76.395,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-72.150,WPos:-2.500,-5.000,-72.150,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-67.930,WPos:-2.500,-5.000,-67.930,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-63.645,WPos:-2.500,-5.000,-63.645,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-59.465,WPos:-2.500,-5.000,-59.465,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-55.220,WPos:-2.500,-5.000,-55.220,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-51.000,WPos:-2.500,-5.000,-51.000,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-46.755,WPos:-2.500,-5.000,-46.755,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-42.540,WPos:-2.500,-5.000,-42.540,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-38.295,WPos:-2.500,-5.000,-38.295,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-34.095,WPos:-2.500,-5.000,-34.095,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-29.845,WPos:-2.500,-5.000,-29.845,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-25.635,WPos:-2.500,-5.000,-25.635,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-21.375,WPos:-2.500,-5.000,-21.375,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-17.170,WPos:-2.500,-5.000,-17.170,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-12.915,WPos:-2.500,-5.000,-12.915,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-8.700,WPos:-2.500,-5.000,-8.700,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-5.005,WPos:-2.500,-5.000,-5.005,Buf:1,RX:0,Ln:6,F:865.>
<Run,MPos:-7.225,-5.000,-5.000,WPos:-7.225,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:530.>
ok
<Idle,MPos:-8.000,-5.000,-5.000,WPos:-8.000,-5.000,-5.000,Buf:0,RX:0,Ln:0,F:0.>
gc_sync
gc_motion
ok
gc_comment
gc_spindle
___________M03S8000 ___________
<Run,MPos:-12.475,-5.000,-5.000,WPos:-12.475,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-21.080,-5.000,-5.000,WPos:-21.080,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-29.735,-5.000,-5.000,WPos:-29.735,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-38.410,-5.000,-5.000,WPos:-38.410,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-47.060,-5.000,-5.000,WPos:-47.060,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-55.740,-5.000,-5.000,WPos:-55.740,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-64.385,-5.000,-5.000,WPos:-64.385,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-73.045,-5.000,-5.000,WPos:-73.045,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-81.665,-5.000,-5.000,WPos:-81.665,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-90.365,-5.000,-5.000,WPos:-90.365,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-99.020,-5.000,-5.000,WPos:-99.020,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-107.680,-5.000,-5.000,WPos:-107.680,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-116.300,-5.000,-5.000,WPos:-116.300,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2027.>
ok
gc_dwell
___________N7 G4P2 ___________
ok
gc_motion
___________N8G0X-212.100Y-188.100Z-89.580 ___________
ok
gc_comment
gc_comment
gc_motion
___________N10G0X-208.356Y-181.585 ___________
gc_motion
___________N11G1Z-92.755F127.0 ___________
gc_motion
___________N12G1F381.0 ___________
gc_motion
___________N13G1X-209.118Y-181.087 ___________
<Run,MPos:-121.295,-7.575,-6.190,WPos:-121.295,-7.575,-6.190,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-125.620,-16.170,-10.160,WPos:-125.620,-16.170,-10.160,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-129.970,-24.820,-14.155,WPos:-129.970,-24.820,-14.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-134.325,-33.480,-18.155,WPos:-134.325,-33.480,-18.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-138.680,-42.135,-22.155,WPos:-138.680,-42.135,-22.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-143.010,-50.750,-26.135,WPos:-143.010,-50.750,-26.135,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-147.415,-59.505,-30.180,WPos:-147.415,-59.505,-30.180,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-151.725,-68.070,-34.135,WPos:-151.725,-68.070,-34.135,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-156.110,-76.790,-38.160,WPos:-156.110,-76.790,-38.160,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-160.455,-85.430,-42.155,WPos:-160.455,-85.430,-42.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-164.815,-94.090,-46.155,WPos:-164.815,-94.090,-46.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-169.170,-102.755,-50.155,WPos:-169.170,-102.755,-50.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-173.520,-111.405,-54.150,WPos:-173.520,-111.405,-54.150,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-177.880,-120.070,-58.155,WPos:-177.880,-120.070,-58.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-182.215,-128.685,-62.135,WPos:-182.215,-128.685,-62.135,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-186.590,-137.380,-66.150,WPos:-186.590,-137.380,-66.150,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-190.945,-146.045,-70.155,WPos:-190.945,-146.045,-70.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-195.300,-154.705,-74.155,WPos:-195.300,-154.705,-74.155,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-199.645,-163.340,-78.145,WPos:-199.645,-163.340,-78.145,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-203.995,-171.985,-82.135,WPos:-203.995,-171.985,-82.135,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-208.380,-180.700,-86.160,WPos:-208.380,-180.700,-86.160,Buf:4,RX:0,Ln:8,F:3148.>
<Run,MPos:-211.925,-187.750,-89.420,WPos:-211.925,-187.750,-89.420,Buf:4,RX:0,Ln:8,F:116.>
<Run,MPos:-210.225,-184.835,-89.580,WPos:-210.225,-184.835,-89.580,Buf:3,RX:0,Ln:10,F:1998.>
<Run,MPos:-208.355,-181.585,-89.690,WPos:-208.355,-181.585,-89.690,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-90.110,WPos:-208.355,-181.585,-90.110,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-90.535,WPos:-208.355,-181.585,-90.535,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-90.965,WPos:-208.355,-181.585,-90.965,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-91.380,WPos:-208.355,-181.585,-91.380,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-91.805,WPos:-208.355,-181.585,-91.805,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-92.235,WPos:-208.355,-181.585,-92.235,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-92.650,WPos:-208.355,-181.585,-92.650,Buf:2,RX:0,Ln:11,F:127.>
<Run,MPos:-209.110,-181.090,-92.755,WPos:-209.110,-181.090,-92.755,Buf:0,RX:0,Ln:0,F:158.>
<Idle,MPos:-209.120,-181.085,-92.755,WPos:-209.120,-181.085,-92.755,Buf:0,RX:0,Ln:0,F:0.>
Her it wouldnt start at all:
Test Waitingā¦
gc_wait_for_idle
ok
gc_sync
gc_parser_state
ok
gc_spindle
gc_wait_for_idle
gc_homing
<Run,MPos:0.000,0.000,-1.845,WPos:0.000,0.000,-1.845,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:0.000,0.000,-4.940,WPos:0.000,0.000,-4.940,Buf:0,RX:0,Ln:0,F:28.>
<Run,MPos:-0.025,-0.025,-5.000,WPos:-0.025,-0.025,-5.000,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:-2.255,-2.255,-5.000,WPos:-2.255,-2.255,-5.000,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:-4.605,-4.605,-5.000,WPos:-4.605,-4.605,-5.000,Buf:1,RX:0,Ln:-1,F:181.>
ok
gc_wait_for_idle
ok
gc_sync
gc_comment
gc_comment
gc_comment
gc_comment
gc_comment
gc_comment
gc_wait_for_idle
ok
gc_units(INCH)
gc_wait_for_idle
gc_simulation_tool
gc_comment
gc_comment
gc_spindle
gc_dwell
ok
gc_comment
gc_motion
gc_motion
gc_wait_for_idle
<Run,MPos:-5.965,-5.000,-5.000,WPos:-5.965,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2106.>
<Run,MPos:-13.850,-5.000,-5.000,WPos:-13.850,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-22.465,-5.000,-5.000,WPos:-22.465,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-31.145,-5.000,-5.000,WPos:-31.145,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-39.855,-5.000,-5.000,WPos:-39.855,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-48.465,-5.000,-5.000,WPos:-48.465,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-57.140,-5.000,-5.000,WPos:-57.140,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-65.810,-5.000,-5.000,WPos:-65.810,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-74.440,-5.000,-5.000,WPos:-74.440,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-83.105,-5.000,-5.000,WPos:-83.105,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-91.760,-5.000,-5.000,WPos:-91.760,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-100.380,-5.000,-5.000,WPos:-100.380,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-109.065,-5.000,-5.000,WPos:-109.065,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-117.630,-5.000,-5.000,WPos:-117.630,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:1366.>
ok
gc_tool
gc_wait_for_idle
o<Idle,MPos:-120.000,-5.000,-5.000,WPos:-120.000,-5.000,-5.000,Buf:0,RX:0,Ln:0,F:0.>
<Idle,MPos:-120.000,-5.000n:0,F:0.>
GRBL_FEEDHOLD
GRBL_RESET
SET MACHINE STATE: INIT
[Check Door]
SET MACHINE STATE: DOOR_PAUSE
nCarbideMotion 0.9h
gc_wait_for_idle
ok
gc_homing
<Idle,MPos:-120.000,-5.000,0.000,WPos:-120.000,-5.000,0.000,Buf:1,RX:0,Ln:-1,F:0.>
<Run,MPos:-120.000,-5.000,-2.135,WPos:-120.000,-5.000,-2.135,Buf:1,RX:0,Ln:-1,F:1000.>
<Run,MPos:-120.000,-5.000,-4.995,WPos:-120.000,-5.000,-4.995,Buf:0,RX:0,Ln:0,F:28.>
Her eit stopped at line 17:
Test Waitingā¦
gc_wait_for_idle
ok
gc_sync
gc_parser_state
ok
gc_spindle
gc_wait_for_idle
gc_homing
gc_wait_for_idle
gc_sync
gc_comment
gc_comment
gc_comment
gc_comment
gc_comment
gc_comment
gc_wait_for_idle
ok
gc_units(INCH)
gc_wait_for_idle
gc_simulation_tool
gc_comment
gc_comment
gc_spindle
gc_dwell
ok
gc_comment
gc_motion
gc_motion
gc_wait_for_idle
<Run,MPos:-6.060,-5.000,-5.000,WPos:-6.060,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2106.>
<Run,MPos:-13.965,-5.000,-5.000,WPos:-13.965,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-22.660,-5.000,-5.000,WPos:-22.660,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-31.310,-5.000,-5.000,WPos:-31.310,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-39.985,-5.000,-5.000,WPos:-39.985,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-48.615,-5.000,-5.000,WPos:-48.615,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-57.315,-5.000,-5.000,WPos:-57.315,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-65.920,-5.000,-5.000,WPos:-65.920,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-74.640,-5.000,-5.000,WPos:-74.640,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-83.220,-5.000,-5.000,WPos:-83.220,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-91.960,-5.000,-5.000,WPos:-91.960,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-100.545,-5.000,-5.000,WPos:-100.545,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-109.310,-5.000,-5.000,WPos:-109.310,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-117.760,-5.000,-5.000,WPos:-117.760,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:1366.>
ok
gc_tool
gc_wait_for_idle
ok
gc_spindle
ok
gc_motion
gc_motion
gc_motion
gc_do_tool_probe
<Run,MPos:-116.195,-5.000,-5.000,WPos:-116.195,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-107.575,-5.000,-5.000,WPos:-107.575,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-98.875,-5.000,-5.000,WPos:-98.875,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-90.270,-5.000,-5.000,WPos:-90.270,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-81.570,-5.000,-5.000,WPos:-81.570,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-72.920,-5.000,-5.000,WPos:-72.920,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-64.205,-5.000,-5.000,WPos:-64.205,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-55.635,-5.000,-5.000,WPos:-55.635,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-46.945,-5.000,-5.000,WPos:-46.945,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-38.320,-5.000,-5.000,WPos:-38.320,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-29.605,-5.000,-5.000,WPos:-29.605,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-20.970,-5.000,-5.000,WPos:-20.970,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-12.280,-5.000,-5.000,WPos:-12.280,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:2600.>
<Run,MPos:-4.060,-5.000,-5.000,WPos:-4.060,-5.000,-5.000,Buf:2,RX:0,Ln:6,F:1014.>
<Run,MPos:-2.500,-5.000,-6.665,WPos:-2.500,-5.000,-6.665,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-10.880,WPos:-2.500,-5.000,-10.880,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-15.145,WPos:-2.500,-5.000,-15.145,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-19.350,WPos:-2.500,-5.000,-19.350,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-23.595,WPos:-2.500,-5.000,-23.595,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-27.815,WPos:-2.500,-5.000,-27.815,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-32.030,WPos:-2.500,-5.000,-32.030,Buf:1,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-35.055,WPos:-2.500,-5.000,-35.055,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-37.605,WPos:-2.500,-5.000,-37.605,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-40.250,WPos:-2.500,-5.000,-40.250,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-42.940,WPos:-2.500,-5.000,-42.940,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-45.590,WPos:-2.500,-5.000,-45.590,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-48.260,WPos:-2.500,-5.000,-48.260,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-50.920,WPos:-2.500,-5.000,-50.920,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-53.595,WPos:-2.500,-5.000,-53.595,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-56.240,WPos:-2.500,-5.000,-56.240,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-58.915,WPos:-2.500,-5.000,-58.915,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-61.580,WPos:-2.500,-5.000,-61.580,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-64.250,WPos:-2.500,-5.000,-64.250,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-66.900,WPos:-2.500,-5.000,-66.900,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-69.575,WPos:-2.500,-5.000,-69.575,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-72.230,WPos:-2.500,-5.000,-72.230,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-74.940,WPos:-2.500,-5.000,-74.940,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-77.560,WPos:-2.500,-5.000,-77.560,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-80.245,WPos:-2.500,-5.000,-80.245,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-82.930,WPos:-2.500,-5.000,-82.930,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-85.555,WPos:-2.500,-5.000,-85.555,Buf:1,RX:0,Ln:6,F:800.>
<Run,MPos:-2.500,-5.000,-88.220,WPos:-2.500,-5.000,-88.220,Buf:1,RX:0,Ln:6,F:152.>
[PRB:-2.500,-5.000,-87.715:1]
ok
gc_wait_for_idle
ok
gc_sync
gc_motion
ok
gc_do_tool_probe
<Run,MPos:-2.500,-5.000,-85.775,WPos:-2.500,-5.000,-85.775,Buf:0,RX:0,Ln:0,F:2.>
<Run,MPos:-2.500,-5.000,-87.450,WPos:-2.500,-5.000,-87.450,Buf:1,RX:0,Ln:6,F:200.>
[PRB:-2.500,-5.000,-87.710:1]
ok
<Idle,MPos:-2.500,-5.000,-87.865,WPos:-2.500,-5.000,-87.865,Buf:0,RX:0,Ln:0,F:0.>
gc_wait_for_idle
ok
gc_sync
gc_motion
ok
gc_motion
gc_wait_for_idle
<Run,MPos:-2.500,-5.000,-84.810,WPos:-2.500,-5.000,-84.810,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-80.585,WPos:-2.500,-5.000,-80.585,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-76.355,WPos:-2.500,-5.000,-76.355,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-72.125,WPos:-2.500,-5.000,-72.125,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-67.905,WPos:-2.500,-5.000,-67.905,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-63.680,WPos:-2.500,-5.000,-63.680,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-59.430,WPos:-2.500,-5.000,-59.430,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-55.195,WPos:-2.500,-5.000,-55.195,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-50.985,WPos:-2.500,-5.000,-50.985,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-46.760,WPos:-2.500,-5.000,-46.760,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-42.515,WPos:-2.500,-5.000,-42.515,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-38.270,WPos:-2.500,-5.000,-38.270,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-34.030,WPos:-2.500,-5.000,-34.030,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-29.805,WPos:-2.500,-5.000,-29.805,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-25.595,WPos:-2.500,-5.000,-25.595,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-21.350,WPos:-2.500,-5.000,-21.350,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-17.145,WPos:-2.500,-5.000,-17.145,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-12.895,WPos:-2.500,-5.000,-12.895,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-8.660,WPos:-2.500,-5.000,-8.660,Buf:2,RX:0,Ln:6,F:1270.>
<Run,MPos:-2.500,-5.000,-5.000,WPos:-2.500,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:1027.>
<Run,MPos:-7.285,-5.000,-5.000,WPos:-7.285,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:530.>
ok
gc_sync
gc_motion
ok
gc_comment
gc_spindle
<Run,MPos:-12.600,-5.000,-5.000,WPos:-12.600,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-21.225,-5.000,-5.000,WPos:-21.225,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-30.000,-5.000,-5.000,WPos:-30.000,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-38.540,-5.000,-5.000,WPos:-38.540,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-47.235,-5.000,-5.000,WPos:-47.235,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-55.865,-5.000,-5.000,WPos:-55.865,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-64.535,-5.000,-5.000,WPos:-64.535,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-73.170,-5.000,-5.000,WPos:-73.170,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-81.855,-5.000,-5.000,WPos:-81.855,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-90.480,-5.000,-5.000,WPos:-90.480,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-99.170,-5.000,-5.000,WPos:-99.170,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-107.785,-5.000,-5.000,WPos:-107.785,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:2600.>
<Run,MPos:-116.490,-5.000,-5.000,WPos:-116.490,-5.000,-5.000,Buf:1,RX:0,Ln:6,F:1865.>
ok
gc_dwell
ok
gc_motion
___________N8G0X-212.100Y-188.100Z-89.565 ___________
ok
gc_comment
gc_comment
gc_motion
gc_motion
___________N11G1Z-92.740F127.0 ___________
gc_motion
gc_motion
gc_motion
___________N14G1X-209.245Y-180.998 ___________
gc_motion
___________N15G1X-209.372Y-180.889 ___________
gc_motion
___________N16G1X-210.571Y-179.787 ___________
<Run,MPos:-121.550,-8.080,-6.425,WPos:-121.550,-8.080,-6.425,Buf:6,RX:20,Ln:8,F:3148.>
ok
gc_motion
___________N17G1X-210.693Y-179.660 ___________
gc_motion
___________N18G1X-210.794Y-179.533 ___________
gc_motion
___________N19G1X-210.896Y-179.403 ___________
<Run,MPos:-125.710,-16.350,-10.240,WPos:-125.710,-16.350,-10.240,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-130.070,-25.020,-14.245,WPos:-130.070,-25.020,-14.245,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-134.425,-33.675,-18.245,WPos:-134.425,-33.675,-18.245,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-138.765,-42.305,-22.230,WPos:-138.765,-42.305,-22.230,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-143.135,-50.995,-26.245,WPos:-143.135,-50.995,-26.245,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-147.490,-59.650,-30.240,WPos:-147.490,-59.650,-30.240,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-151.840,-68.295,-34.235,WPos:-151.840,-68.295,-34.235,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-156.265,-77.100,-38.300,WPos:-156.265,-77.100,-38.300,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-160.560,-85.635,-42.240,WPos:-160.560,-85.635,-42.240,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-164.910,-94.280,-46.235,WPos:-164.910,-94.280,-46.235,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-169.260,-102.930,-50.230,WPos:-169.260,-102.930,-50.230,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-173.620,-111.595,-54.230,WPos:-173.620,-111.595,-54.230,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-177.980,-120.265,-58.235,WPos:-177.980,-120.265,-58.235,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-182.315,-128.890,-62.220,WPos:-182.315,-128.890,-62.220,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-186.695,-137.595,-66.240,WPos:-186.695,-137.595,-66.240,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-191.035,-146.225,-70.225,WPos:-191.035,-146.225,-70.225,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-195.385,-154.870,-74.220,WPos:-195.385,-154.870,-74.220,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-199.750,-163.545,-78.225,WPos:-199.750,-163.545,-78.225,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-204.115,-172.225,-82.235,WPos:-204.115,-172.225,-82.235,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-208.460,-180.865,-86.225,WPos:-208.460,-180.865,-86.225,Buf:10,RX:0,Ln:8,F:3148.>
<Run,MPos:-211.945,-187.795,-89.425,WPos:-211.945,-187.795,-89.425,Buf:10,RX:0,Ln:8,F:116.>
<Run,MPos:-210.125,-184.660,-89.565,WPos:-210.125,-184.660,-89.565,Buf:9,RX:0,Ln:10,F:1998.>
<Run,MPos:-208.355,-181.585,-89.685,WPos:-208.355,-181.585,-89.685,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-90.105,WPos:-208.355,-181.585,-90.105,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-90.530,WPos:-208.355,-181.585,-90.530,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-90.950,WPos:-208.355,-181.585,-90.950,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-91.375,WPos:-208.355,-181.585,-91.375,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-91.800,WPos:-208.355,-181.585,-91.800,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-92.225,WPos:-208.355,-181.585,-92.225,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-208.355,-181.585,-92.645,WPos:-208.355,-181.585,-92.645,Buf:8,RX:0,Ln:11,F:127.>
<Run,MPos:-209.155,-181.060,-92.740,WPos:-209.155,-181.060,-92.740,Buf:5,RX:0,Ln:15,F:381.>
<Run,MPos:-210.100,-180.220,-92.740,WPos:-210.100,-180.220,-92.740,Buf:4,RX:0,Ln:16,F:381.>
<Idle,MPos:-210.895,-179.405,-92.740,WPos:-210.895,-179.405,-92.740,Buf:0,RX:0,Ln:0,F:0.>
Ok, we need to troubleshoot a little deeper, so probably better to handle it via the support@ so we can track the ticket. What are your computer specs?
I had the same issue with my new Nomad today. Tried Everything. Just typed in this code and its gone.
Have no idea what it does tho⦠But the error is gone.
Thanks.
