I was running version 634 and now I downloaded v640. During the machine setup when it asks me to initialize the machine the z axis homes fine. The x axis and y axis move and the machine starts to violently shake.also the x axis moves to the left away from homing switch. …Any thoughts.
all axis move smoothly when power is off.
Do the homing switches test as working?
The z axis homes and switcg works properly the x and y never make it to the homing switch before i shut the machine down
Have you tested the x & y switches with a piece of metal (Screwdriver or whatever) To make sure they are both responsive?
problem turned out to be loose wiring to the x axis motor.i could wiggle the wires coming out of the motor and mimic the problem…ordering new motor.
