Greetings,
So I did my first alu project on the machine today. 2pcs dogbone door handle for a local veterinerian clinic.
If it is of use to anyone, some details:
10mm stock of 6063 aluminium.
Rennie Tool Co (UK) 1/4" single flute coated cutter.
18 000 RPM on the Makita RT0702C router.
0,35mm DOC, and 914mm/min feedrate
Everything worked like a charm and turned out great. Used a DeWalt shopvac for chip extraction. Not a single chip seemed to have escaped. No “re-cutting” of any chips from what I observed. And yes, I put a fresh bag in to prevent any fire hazard.
I guess you are wondering about the keyhole? They use a different door to enter the building and unlock from the inside. It’s what the client wanted. I did point this out to them from the beginning
