Finally made the time to make a new sucker.
I just mounted it, so time will tell if I want or need some alterations.
Try it if you want, be aware it may still be a work in progress.
I designed it around the stuff I had laying around, you’ll need some;
bristle (amazon)
Ttracks 19x12,5 mm
Track M6 bolts
m3 bolts/nuts
Though it would be best to screw the Ttrack onto the Z-plus plate, I decided to design it so I did not need to make any changes to the Z-plus. I have an old Shapeoko, without the cable guides, so I could use these mounting holes. Al screwholes are slots, so you have some adjustability.
I included the step file, make any changes or improvements you want, please let me know if you made improvements.
You’ll find all files (including .step) here
https://grabcad.com/library/z-plus-sucker-shapeoko-1
the bristle I used;
