I’m using the trial version of CC Pro to check out how inlays are handled for the Male portion. Using the Advanced VCarve toolpath, what are the suggested values for starting depth and max depth if the bottom gap is 0.02 inches. The Female depth is 0.2 inches and I’m using a 45 deg Vbit. Thanks.
has a full tutorial i wrote up… i used 0.2" as well so you can just use all values i used as is…
Great tutorial! Very clear with additional setup points worth learning. Thank you.
