Materials in tool path tab
When I set up my project I selected hard plastic for the material. When I was generating tool paths plastic was not an option. Is this a bug?
The materials in the Setup don’t seem to do anything at all. The materials available as toolpaths are completely independent, and the materials available for the simulation are completely different as well.
It’s probably a holdover from when CC tried to calculate speeds and feeds (instead of using a ‘database’), and should just be ignored now.
Correct.
I use it and the Machine selection (which similarly doesn’t do anything) as reminders for what a given job was set up for.
