I have a board that is 1.25" thick. What is the max depth I can cut safely. Thanks
Depends on:
- workholding — secure enough, but low enough to be cleared?
- endmill and flute length — see: https://docs.carbide3d.com/support/#tooling-support
- part geometry — is the top fo the stock low enough to allow the necessary length of endmill over it? Is the tallest section shorter than the flutes?
