McFly 602E vs 603E
I need to replace the inserts on my McFly (602E) and noticed the McFly shank in the store is 603E.
I assume the inserts are the same for both McFly shanks, but I’m curious what difference(s) between them is(are). Both are 1/4" with four inserts and look the same.
Thanks!
The #602 and #603 should differ by shaft diameter, one is 1/4", the other 8mm.
If that’s not clear, it’s a typo in the description.
Ah, I see it now. The third image in the gallery is similar to the first image, but shows the #603 where the first image is the #602. I didn’t notice the size specification buttons, but see them now and the descriptions appear correct.
When I created the topic I was on the third image (#603), not realizing they were different, hence my questioning of the universe.
Thanks Will!
