Just got new McFly bit today. Noticed that when setting it on flat surface that it has a slight wobble to it. Trying to determine the high points but no success. Is this normal?
I’ve got a significant amount of white oak to remove and don’t want to screw up. Anticipate testing on scrap tomorrow.
There are four individual blades on the McFly and you can loosen (and replace) them. Try loosening them slightly, place it on a flat surface to square them and then tighten. See if that helps.
