Meet the New Shapeoko HDM V3
Thanks for the detailed feedback, and I know you’ve spent time with the machine.
We didn’t feel the need to add a Z-axis brake, as the axis is now counterbalanced with a gas strut. It’s a simpler, more robust solution that removes any motor holding load and doesn’t introduce extra complexity. Z clearance has been modestly increased, but more importantly, the front of the machine now has workholding—opening up vertical setups and edge machining. That’s a much more impactful upgrade than, say, another 30 of Z clearance.
As for the Z axis itself, we haven’t seen any deflection issues that would warrant making it thicker. If you’re seeing something in your setup or toolpaths that suggests otherwise, we’d be curious to know more.
We considered moving the Y-axis rails and screws to the sides, but that change would compromise machine stiffness—especially when combined with the new overreach and larger cross members. Instead, we focused on making the side panels easier to remove on V3, which helps access while keeping rigidity intact. (I removed them on my own V1 as well.)
I generally don’t use compressed air when running wood jobs, but for Aluminium, I do use it to clean the machine down. I’m thousands of jobs in and am yet to damage or jam one of our ballscrews with wipers. These wipers: they’re the same design as before. We’ve had very few issues, and as far as we know, we’re still the only company shipping custom wipers as standard. They occasionally come loose but perform well overall.
I’ll ask if @wmoy can share photos with the guards off.
As for the machine size, HDM isn’t trying to be a 2x2 or 4x4 platform. It’s purpose-built for cutting tough materials all day, every day, with accuracy and repeatability. If your workflow revolves around sheet material or nested jobs, I’d recommend looking at the Shapeoko 5 Pro instead. That’s the right tool for that kind of work. HDM is more about precision, power, and rigidity in a compact footprint.
To add a bit in the accuracy, squareness, and precision of assembly:
My V3 was square enough I could not see any difference on diagonals with the tape measure.
When I ran a dial indicator across the front crossmember it was +0.003/-0.012 with zero being far right…as delivered. After assembly, shipping, removal from the crate, lifting into my Outback, and placing it on my bench. So not only was it pretty accurately setup, it held during handling. Slightly adjusting a Y homing switch I was able to get it within +0.001/- 0.003 across the whole crossmember. So assembly was fantastic and the machining well done.
Life has kept me from finishing my enclosure and making chips… hopefully this coming weekend.
Q: How thick is the aluminum table?
(I really appreciate the idea of the aluminum table – makes using a mister so much more attractive.)
18 mm or almost 3/4 of an inch.
It seems to me that there is insufficient travel on all axes. Is there some reason for the smaller cut dimensions–like price?
As noted in the original announcement:
https://carbide3d.com/blog/introducing-shapeoko-hdm/
a high-performance CNC router that could be delivered on a pallet ready-to-run
Will beat me to a reply, Allen. For a beam such as the gantry, stiffness is inversely proportional to the third power of the length. If you increase the span of the gantry by 25%, you will double the deflection under cutting forces.
Ahhh! Numbers, I like 'em–retired statistics guy. Thank you for the lesson. Much appreciated, Randy.
I appreciate your appreciation, Allen. :slight_smile: I’m a mechanical engineer, and there is a new little part on my SolidWorks screen at work right now that I’ve been updating the design of. Part of my internal “design it reasonably” thought process is “can I make that with my Nomad?” and includes aspects such as cutter deflection when machining details etc. so things really go full circle.
Just curious, what benefits would you expect with “something less limited”?
One thing would be the ability to have dual Y axis homing, and proper pause support.
Right now it’s one or the other.
Perhaps with another board, we could get IOT style controls on relays - it would be nice to control dust collection automatically, for example.
It has dual-axis homing. I’m unsure what you mean by proper sause support - we do support pause, stop, and jump to line.
The Pro 5 compromised the GRBL build to include dual Y axis homing, but sacrificed pause with stop spindle & retract. It only does a feed hold, leaving the spindle running in place.
1 Pause with stop spindle and retract
2 4th axis
3 ATC
Throughout this forum C3D uses the excuse that GRBL limits their ability to add the features requested by users.
4th axis & ATC were two reasons my last three machines were not Carbide machines.
I’m not knocking Carbide, I still use the three I own now but I wanted the ability too do more operations once I had a project on the table.
Carbide’s competitors are all incorporating ATC, 4th Axis, Lasers, Touch Probes, Touch Scn Monitors, etc with their offerings at very competitive prices.
Just my opinion but I think Carbide needs to reevaluate their decision to not offer these options.
Again, not hating on Carbide, just want what I want to make my life easier and be able to expand my offerings to my clients.
Will there be one in Austin next month for a demo?
I’m strongly considering the drive from Dallas.
We’re not taking an HDM to Austin, but we will have the Shapeoko 5 Pro 4x4
I believe I have a V1, is there an upgrade path to V3?
I want the vertical machining in front.
Unfortunately, there’s no real path to the vertical workholding on the V1 because the entire base and Y-axis were changed to accommodate that. I think the only constant part was the gantry tube and the Z axis.
I am one of the early purchasers of the HDM and have used it extensively and successfully. I always thought that it did not get enough love, so I a glad to see that Carbide3D is still paying attention to it. It is a more capable machine than most people realize. The upgrades are nice, but not essential for a V1 owner. The Saunders table addresses most of the issues that the new one does (albeit at greater cost) except for the vertical fixture possibility (great addition!). I understand why no ATC. But quick-change (manual) preset tooling and a lower speed spindle would go a very long way in addressing the primary limitations of the machine. A gas strut retrofit for the V1 z would be handy, though (hint, hint).
