Meet the New Shapeoko HDM V3
We’re excited to officially launch the Shapeoko HDM V3 the latest version of the HDM. This machine is the result of years of testing, rebuilding, and obsessing over every last detail. It’s built to cut wood, aluminum, and brass with speed and precision—and run all day without breaking a sweat.
Version 3.0 builds on everything people love about the HDM, with meaningful upgrades to performance, reliability, and usability.
Built in the USA, from the Ground Up
All-Aluminum Hybrid Table
V3 now ships with a solid aluminum Hybrid Table for serious rigidity and rock-solid workholding. We’ve included M6 threaded holes and front-facing vertical clamping—so whether you’re machining edges or building complex setups, it’s ready.
Heavy-Duty Frame
Every structural part is custom-designed for the HDM—from our massive X-axis extrusion to the billet-machined Y-axis. All machined in-house. All built to last.
Motion System: Overbuilt (on Purpose)
We’ve packed industrial-grade motion hardware into every HDM:
  • HG15 Linear Rails and Carriages on all axes for smooth, precise motion
  • 16mm Ball Screws, built to tight tolerances for low backlash and repeatability
  • Dual Angular Contact Bearings to lock down each screw
  • Custom Ball Screw Wipers (on X and Y) to keep things clean
  • All mounted directly to machined aluminum—no flexy T-slots or shortcuts
80mm Water-Cooled Spindle
At the center of it all is a high-torque, 4-pole water-cooled spindle with a wide 8,000–24,000 RPM range:
  • Choose from 1.5kW (110V) or 2.2kW (220V) options
  • ER-20 collet holds up to 1/2” (13mm) tools
  • Spindle speed is fully G-code controlled—no knobs, no guesswork
  • Comes with a CW-3000 chiller to keep things cool and quiet
Carbide Warthog Electronics
HDM V3 features our all-new Carbide Warthog electronics, designed in-house for improved reliability, signal integrity, and ease of use. It’s the most refined control system we’ve ever shipped.
Whether you’re cutting aluminum, running a jobshop or educating the next generation of operators, the HDM V3 is ready for it.
Full specs are in the store here.
Wow! Specs look very promising for serious milling. Is the 1.5kw spindle water cooled as well? Spec sheet does not specify this.
It does state in the specs that for the power requirements for the 110v version is 2 x 110v outlets for spindle chiller and motion electronics.
Thanks, you are correct. I failed to scroll down that far to see that.
I failed to scroll through it all as well until you said something. Lol It’s definitely a beast of a machine!
Yep, If I have a need to start seriously machining alloys of sorts this would easily fit the bill.
There I was getting all excited then I read that it does not ship to the UK!
I’m sure that there is a reason, please can someone enlighten me?
The HDM ships on a pallet, and we haven’t been able to work up a suitable shipping partner at a reasonable price for overseas shipments.
The SO5 Pro, in two separate boxes is far more manageable to ship.
Please check in w/ the folks at sales to confirm the above and see if they can work up an alternative.
All-new Carbide Warthog electronics?
Is this still a 328 processor grbl system? or have you actually taken a step into the twenty-first century with something less limited?
To reiterate (mostly to myself)
Any thoughts on making the aluminum table available for v2 owners - I assume the slats would be a bit longer. Will the e-stop button plug/play into a v2? If so, will it be available?
This seriously needs an upgrade to closed stepper models
Let me have a word with @robgrz on the table.
Unfortunately, the power pendant only works with the new controller, so it isn’t backdatable.
Thank you sir! I’ll be interest to see what you find.
We’ll have to check and see how much of the solid extrusion we have right now. (Making it a question of whether or not we can do it now, or if we need to reorder first)
If other HDM users want to chime in if they’d be interested, that will help.
At a reasonable price, I’ll commit to a set.
Wow this looks excellent! I’m an original HDM owner - is there a good summary somewhere of the enhancements and modifications since V1?
Not much of an upgrade. How about offering closed stepper motors as an option this is supposed to be a high end machine.
I was really hopeful you would add a Z axis brake and possibly closed loop, even taller slightly thicker Z axis with more clearance and travel, Ball nut and slider block oiling ports that are easy to access without unbolting the ball nuts or slider blocks, active 3d touch probing, and swap the Y axis rails and screws to being on the outside vs the top.
Vacuuming the chips out of the channel and ball screw pass through hole front and rear is not pleasant. I have to use a coat hanger bent into a pick to dig out the chips out from what I call the ballnut cave. I don’t want to use compressed air and risk blowing debris back into the ballnut.
The bigger cross beams along with the front over reach, front mounting holes, and extra travel is a nice change.
If you shipped with the motors off you could add even more travel. Build it, calibrate it, then pop the motors off with the couplers still attached and ship. Then the user is only 12 bolts and a few power / data cables away from running with even more travel.
Did you come up with a new better ballscrew wiper than what came on the v1?
Can we get pics with the chip guards off as well please.
I get where you’re coming from—closed-loop steppers can be a solid upgrade in some setups. But they don’t always deliver meaningful gains in accuracy or reliability, especially on a machine that’s already highly rigid and properly dialled in.
With the HDM upgrade, we focused on improvements that matter in real-world use: increased rigidity and squareness, better thermal stability, more power, and upgraded electronics. These translate directly into better cut quality, repeatability, and overall performance.
Closed-loop systems often sound great on paper, but in practice, they rarely improve accuracy—and the correction they offer can be slower and limited compared to a well-tuned open-loop system. For our machines and our customers, this direction made more sense.
