MeshCAM 8 installed and initially worked fine for me, but it just had one tool (at that time) defined.
Today, I used the “About, Add Default Tools”, and ever since then when I use “File, Open” it opens the windows file dialog, but then MeshCAM closes/shutdown/crashes (not sure which).
If it is working for you, do you still have MeshCAM v6 installed or did you uninstall it before installing v8?
It appears both versions are using the same AppData folder…
C:\Users{your user account}\AppData\Local\MeshCAM
