I’ve been trying to cut a piece which has parts in 3 different depths: 1.5mm ,1mm and 0mm.
For some reason, MeshCAM toolpath is doing parallel finish on all the surface area. And when I switch the parallel finish off, it does not cut the surface which has to be cut (1.5mm in depth). I’m attaching screenshot for the settings and an .stl file of my design.
@ttumkaya, in the parallel finishing area check Don’t Machine Top of Stock. That will keep MeshCAM from machining any surfaces that touch the top of the stock.
