I’m going to move CM from one windows laptop to another. I vaguely recall reading some of the machines config files are stored on the computer. If I copy the applications directory, is there any other area’s in windows where data files may be hanging out? Thank you in advance.
Rather than trying to move files, re-send the configuration, and reconfigure the BitSetter position if need be.
Resend from the original or do a clean install on the new computer and perform your suggestion?
Clean install on the new computer, then re-send the configuration and re-configure the BitSetter.
If you wish, you can copy any calibration values for steps/mm as well as the location for the BitSetter and reapply those on the new computer.
