If you’re certain the table is flat & parallel to the XY axes, and your stock is a consistent 19.8 mm everywhere, why not just zero off the top of stock & remove 1.8mm?
If you’re uncertain, remove 1.5mm, measure, then adjust your Z to get the remaining 0.3mm
Are you measuring the stock in the same location where you set your Z0? Have you checked multiple locations on the stock after setting your initial Z0?
GCode is GCode. Attach your GCode and we’ll look at it. PS For simple facing operation like this, I recommend Carbide Create. You could create this GCode in about 2-3 minutes. PPS Painter’s Tape and Super Glue is far superior to Tape.
You are removing 0.581 thickness with your first pass, and 0.75 more w/ the second to remove 1.331mm of material.
Agree that if you want to remove material from the surface, it would be far simpler to set the origin there and just remove one layer at the depth per pass, then measure, and then move zero down by the thickness of material remove and repeat or adjust as needed.
OK the bed is level - at least as far as I can tell. A single pass look to be of consistent depth.
For the sake of discussion let’s stipulate a level bed.
The stock is 19.8 mm
The target is 18mm
The tape is .17mm
XYZ zero is espablished with BitZero (1?) So, on top stock surface. Zero is 2x checked manually (eyeball)
after milling
With Tape I’m at 17.5mm milled
I don’t understand why you’re including the tape thickness if you’re setting the origin at the top of the stock — if you’re setting origin there, it doesn’t matter if there’s zero layers of tape or 100 — it doesn’t affect the G-code.
Mount a piece of scrap — set a rough zero relative to it and make a bunch of pencil marks across it — run a surfacing operation which removes a sufficient thickness of material to remove all the pencil marks.
Jog down to the bottom of the surfacing operation — set zero there.
Cut a series of stepped pockets, each of which is a set distance high — measure the steps — are the steps of an even, regular thickness? How does that compare to the height which they should be?
Charles,
This may be a bit easier if you mill to Z zero. Never mind BitZero for a moment. Take you cutting tool down to the top of your tape that’s on the table and touch off. Now move up 18mm and set Z zero. Now adjust your Z values in your code. The first pass will be a positive value and the final pass will be zero (0).
