Minor bug when rapid positioning
I assume this is a bug but it might be intentional. I noticed yesterday that after I did a job where i had slowed the speed down manually, after the job was done and I told the cutter head to rapid position to the current XY, it was still moving at the override speed.
I realize, this picture doesn’t look like much, but you can see the override in place on the left and this is right after I told it to rapid position to the current XY. Interestingly, manually moving it with the on-screen buttons at the “Fast” speed worked just like normal. So only Rapid Position movements appeared to be affected by the override still.
It’s a very minor thing but I wanted to mention it.
When you increase/decrease speed in CM it is persistent until you restart CM. So if you increase 10% that increased speed will stay until you restart CM or decrease the speed back to center. The jogging system is separate from the running mode. That is why jogging seems “normal” compared to the increase/decrease when running a job.
The increase/decrease in speed resets at some point between jobs. The issue of it being persistently retained has been resolved at some point recently. Reset feed factor after slowed tool path - #2 by WillAdams
