Newbie here - Received my XL Shapeoko about 1 month ago. Finally started assembling this weekend. Am at the point in the XL assembly doc where it states
" Install X-Axis Drag Chain Bracket
The X-Axis Drag Chain Bracket is the smaller of the 2 stainless steel ‘L’ shaped brackets. Remove the protective film from bracket as shown in the photo below. (The underside of the film is black, the top side is a white/silver color.)"
I only have one large bracket which appears to be the Y Axis bracket but no “smaller L shaped bracket”. I know there are some differences between the different sizes of machines but I assume I need this bracket?
I ordered the XL from MatterHackers - Do I contact them for any missing parts or Carbide 3d?
I was so hoping to get this up and running this weekend
Thanks William. I’ve sent email with order number. I’ve looked at several assembly videos on line and I am definitely missing the smaller l shaped x axis bracket.
Thanks for the quick response. I will also check out the other documentation you linked to.
