Been searching but can’t seem to find anywhere the options in “Model Shape” are explained.
Particularly the “Merge Type” and what those different options actually do.
I’ve played around with some shapes & it seems some Merge types don’t do anything.
OK, I think I found one solution for @Ed.E challenge
I created 2 rectangles, one on the edge of the slot 0.100 wide and the length of the slot and subtracted a flat shape 0.100 tall.
Then I created a rectangle, also on the edge of the slot, but about 7.75 long & 0.200 wide, made a Angle shape & used the “Max” merge method. I had to add a base height of 0.88 to raise it up to the level of the slot.
Looking at recent post on FB wanting to cut text into a baseball bat…
I created a 2" x 10" rectangle. Created a shape, round, 90°, 1" height, Add
I expected a semi-cylinder but got this
What size & settings would I need to produce a 2" diameter cylinder?
A document explaining how the Model options all work would be really helpful.
