Modular joinery system for blind miter fingerjoint boxes
The Holy Grail of CNC joinery (to my mind at least) is a joint which:
The closest thing at this time is a blind miter fingerjoint:
(still working on a void free joint idea, but the math and geometry are tough)
Wrote up a bit on this at:
and here is the base file for 1/4" thick stock which is 3.5" wide:
all joints_0_25_x_3_5_sawnlid.c2d (672.6 KB)
I’d like to try this in a hexagon shaped box…
Yeah, additional angles are something I’d like to look into — but there is an interaction between the V endmill angle and the angle of the joint — a 60 degree endmill would be needed for a hexagonal box — we’ll have to see, may have to wait until I master the math necessary for the other joinery technique I have in mind.
Wrote up how the joinery/parts are adjusted (basically one goes into Node Edit mode and drags):
Next up is exporting G-Code and cutting the file twice.
