Secondly, I’m a little frustrated with my current situation. Yes, I’ve used the search function to try and discover a solution for my issue, but I have not been able to figure it out.
I am trying to increase efficiency of a very large pocket for a 50" x 26" table epoxy inlay project. The design is a map of the puget sound. In other topics, there has been mention of using a larger endmill to start the pocket, and then dropping down by 1/2 for contour cuts to increase detail on the edge. I tried this and the result is the machine path crossing the design in several places.
*I also made sure that the outer line - which is the issue - is one complete vector. Where it seems to be crossing is places where the design gets a little complex.
Any suggestions? Thank you, in advance, for all of your help!
Wow! That’s extremely relevant… I just tried to do the “old school” nesting by running the 1/4” path and then following with 1/8 and 1/16. I don’t have the “nesting” capability. Maybe it’s time to upgrade to pro
Well… It was as simple as updating Carbide Create! Now to test out nesting and add some advance V carving! Thank you all so much! I will report back with pics from the project!!
