I need a wider drag chain than what I could put on the top of the Y-axis. The 20mm drag chains are just too tight for the USB cable, the power supply cable and the rather thick power cable of my spindle. Do you have any recommendations on how to mount a 30mm wide drag chain to the side of the right Y axis of a standard SO3 without drilling holes into the Y axis extrusions?
Not sure if this will be helpful but I 3D printed my own cable chain and mounts. For the Y-bracket mount I designed it to slip over the Y axis bracket and sit on the Y-axis extrusion. Then I used a cable tie to to tie it down. The details are here http://www.shapeoko.com/forum/viewtopic.php?f=11&t=7883#p62287
I think I will go for some Igus drag chains - they offer the STEP files for all of their products, so I can create custom mounting brackets and 3D print just those.
Definitely agree. I printed mine mainly because I could but also because I needed open drag chains since my wiring was in place and I didn’t want to rewire to install them. I’m also in Canada which always makes selection, shipping and price an issue…
